Network Management
Change tunnel-group mode to L2 via GUI
  • 1.  Change tunnel-group mode to L2 via GUI
    Posted Feb 21, 2017 05:54 PM
    Is it posible to change a tunnel-group type from L3 to L2 via the Web-GUI, rather thanvia the CLI
  • 2.  RE: Change tunnel-group mode to L2 via GUI
    Posted Feb 22, 2017 04:48 AM
    Yep. Configuration > IP > GRE Tunnels > Edit (next to tunnel group) > Select L2. Save.
  • 3.  RE: Change tunnel-group mode to L2 via GUI
    Posted Feb 22, 2017 05:58 PM
    There is no option in edit mode for changing tunnel from L3 to L2. It
    defaults to L3 on creation and I can only change it from the CLI
    ___________________________________________________________________________________________
    This email and any attachments may be confidential and contain privileged information. It is intended for the addressee only. If you are not the intended recipient you must not use, disclose, copy or distribute this communication. Confidentiality or privilege are not waived or lost by reason of the mistaken delivery to you. If you have received this message in error, please delete and notify the sender.
  • 4.  RE: Change tunnel-group mode to L2 via GUI
  • 5.  RE: Change tunnel-group mode to L2 via GUI
    Posted Feb 22, 2017 06:25 AM
    Unfortunately, you get an error on the GUI when you attempt to change a tunnel group that is already established.  Are you getting the same error?
  • 6.  RE: Change tunnel-group mode to L2 via GUI
    Posted Feb 22, 2017 07:03 PM
    As previously suggested, we do get the error because the tunnel-group
    default is L3 and our tunnels are configured L2.
    We cannot add tehm to the Tunnel groups as they are different mode.
    The editing of the tunnel does not have a mode change option on GUI
    interface (possibly OS restriction, we are using 6.4.2.6).
    we change it on the CLI, but were trying to do it only through one GUI
    interface
  • 7.  RE: Change tunnel-group mode to L2 via GUI
    interface
