last person joined: 5 hours ago
Change WPA2 Passphrase (IAOS 4.01, AMP 7.7.5)
  • 1.  Change WPA2 Passphrase (IAOS 4.01, AMP 7.7.5)
    Posted Mar 20, 2014 04:26 PM
    If I am running Instant OS 4.0.1 with AMP 7.7.5. I attempted to change the passphrase of an SSID from the template in AMP 7.7.5. That failed. Not only did the new passphrase fail, but so did the old passphrase. Given the firmware that I have on the IAP and AMP, what is the best way to change the passphrase of an SSID?
  • 2.  RE: Change WPA2 Passphrase (IAOS 4.01, AMP 7.7.5)
    Posted Mar 21, 2014 04:11 PM
    Yes this is possible.  Using templates, the new passphrase will get pushed but the config will be mismatched.  Post the change, please try and re-fetching the template to resolve the mismatch.
    If you are having more issues, please post screenshots of what is happening.
  • 3.  RE: Change WPA2 Passphrase (IAOS 4.01, AMP 7.7.5)
    Posted Mar 24, 2014 05:07 PM
    Thanks Seth. For some reason when I iniitially attempted this, it did not work. Another engineer attempted the process again and it worked. The first time I must have typed the passphrase incorrectly.
