There is another possibility, if you want to continue to use ARM for the auto-assignment of your channels, but if you want to change the available channels. In this case you have to go to "RF" link from the GUI interface and set the valid channels under the parameter "Customize Valid Channels": here you can remove the undesired channels and add new channels.
[If you found my post helpful, please give kudos]
