last person joined: 11 hours ago
Changing from Master-Local to Master-Master CP doesn't work on the backup master
  • 1.  Changing from Master-Local to Master-Master CP doesn't work on the backup master
    Posted Jul 12, 2013 04:04 AM
    Hello Everyone!
    So I am changing my current configuration to a Primary Master -Backup Master model  and the Captive Portal page doesn’t work when it fail it over to the back up. I realize the that the VLAN interface on the backup has a different IP and that is why it ti broken.
    What is the best way to set this up? I am probably missing something obvious.
    You comments would be appreciated!
    C E
  • 2.  RE: Changing from Master-Local to Master-Master CP doesn't work on the backup master
    Posted Jul 12, 2013 06:04 AM
    You need to set the ip cp-redirect-address to the ip address of the VLAN interface on that local controller:
    http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-ip-cp-redirect-address/td-p/236
