Wired Intelligent Edge
Changing Load Balancing L3 to L4 on Aruba 5400 effect?
  • 1.  Changing Load Balancing L3 to L4 on Aruba 5400 effect?
    Posted Jun 27, 2018 08:29 AM
    I would like to know if changing the (default) Load Balancing Method:  L3-based to L4-based may cause traffic disruption or have a negative effect in a production environment.
    Thanks in advance for your advice.
    Best regards
    Oumar
  • 2.  RE: Changing Load Balancing L3 to L4 on Aruba 5400 effect?
    MVP GURU
    Posted Jun 27, 2018 11:37 AM
    It shouldn't.
    The Load Balancing Method L4 should fallback to L3 (L3 to L2) depending on processed packets and it should do it transparently.
    Probably moving from L2 to L3 and finally to L4 the switch, always depending on outgoing traffic it processes (I mean the traffic leaving the LAG's member interfaces), should distribute the data traffic better and better enhancing the LAG members' ports usage (de facto balancing better the data flows)...so the effect should be overall positive.
  • 3.  RE: Changing Load Balancing L3 to L4 on Aruba 5400 effect?
    Posted Jun 29, 2018 07:46 AM
    Hello Parnassus,
    Thanks a million for the feedback.
    I appreciate your support.
    Best regards
    Oumar
