Hi ,i am using Aruba 3600 controller curently operating in GB regulatory domain.I want to change the regulatory domain of my controller.Can some one tell me how to do so and is there a reboot required for the change to take effect.
You would need to run the startup Wizard again.
Thanks for the answer,If i change the regulatory domain of APs in a specific group using AP profiles.In that case would i be needing to reboot controller for the changes to take effect.
If you just change it on the regulatory domain profile, it does not require a controller reboot. My answer is if you wanted to change the regulatory domain of an entire controler.
Thanks ,really appricate the prompt response.
