Changing tacacs+ password
This thread has been viewed 22 times
  • 1.  Changing tacacs+ password
    Posted Apr 01, 2021 06:24 PM
    There doesn;t seem to be much docn ( i.e. examples)  on using the  changing TACACS+ password on next login option in a CPPM Local User  account.
    I have a 2930 switch running  fairly new firmware
    as part of the confgi I have aaa authentication login privilege-mode set up so  when i log in I don;t have to type  enable<cr> enter username/password
    I can quite happily set the cppm checkbox and log into t e switch. at no point an i prompted to enter another password  burt looking in the cppm local user  table, the change tacacs password  checkbox has been cleared.
    Tried removing the  login privilege-mode statement so I had to type enable .... no differnce .
    Anyone using this in conjunction with  arubsa 2930 switrches
    Cppm is 6.9.5 BTW
    Rgds
    Alex
    Alex Sharaz
  • 2.  RE: Changing tacacs+ password
    MVP EXPERT
    Posted Apr 02, 2021 03:15 PM
    Hi Alex,
    Maybe my TACACS template will help you.
    tacacs-server host 1.2.3.4 key "mysecret"
    tacacs-server host 1.2.3.5 key "mysecret"
    tacacs-server timeout 5
    ###SSH###
    aaa authentication ssh login tacacs local
    aaa authentication ssh enable tacacs local
    ###TELNET###
    aaa authentication telnet login tacacs local
    aaa authentication telnet enable tacacs local
    ###CONSOLE###
    aaa authentication console login tacacs local
    aaa authentication console enable tacacs local
    aaa authorization commands auto
    no web-management management-url
    no telnet-server
    Marcel Koedijk | MVP Guru 2021 | ACMP | ACCP | ACDA | Ekahau ECSE | Not an HPE Employee | Opionions are my own
  • 3.  RE: Changing tacacs+ password
    Posted Apr 08, 2021 05:29 AM
    If I remember correctly, the ArubaOS Switch does not support password changes over TACACS+. You can ask your Aruba Partner or Aruba SE to add your request for this feature which is already registered as SWITCH-I-509.
  • 4.  RE: Changing tacacs+ password
    Posted Apr 08, 2021 12:04 PM
    Ah!
    ok. Many thanks
    Rgds
    Alex
