Wired Intelligent Edge
Changing the Member ID of switches in a VSF stack
This thread has been viewed 21 times
  • 1.  Changing the Member ID of switches in a VSF stack
    Posted Jan 14, 2021 07:34 PM
    I'd like to know if there is a command or easy way to reorder the member ID numbers of a VSF stack? For example, I have three 2930F switches, A, B and C in a stack as follows:
    ID 1 - Switch A
    ID 2 - Switch B
    ID 3 - Switch C
    I'd like to move Switch C to member ID 1, so that the stack looks like the following
    ID 1 - Switch C
    ID 2 - Switch B
    ID 3 - Switch A
    I'm not concerned with which switch is the commander, if the role changes, or if there is downtime involved.
  • 2.  RE: Changing the Member ID of switches in a VSF stack
    MVP GURU
    Posted Jan 14, 2021 07:48 PM
    Hi! have a look at Aruba Backplane Stacking and VSF Best Practice Guide or Aruba Management and Configuration Guide for your switch series (note: I assume you're referring to VSF deployment on ArubaOS-Switch based switch series but those suggested guides can be found also for ArubaOS-CX based switch series VSF deployments): renumbering VSF Member Id is a disruptive process (remove -> rejoin with new Id).
  • 3.  RE: Changing the Member ID of switches in a VSF stack
    Posted Jan 14, 2021 07:53 PM
    Hi thanks for the quick response.
    I'll check those guides but I think you answered my question when you said "renumbering VSF Member Id is a disruptive process (remove -> rejoin with new Id)" as I know how to remove and rejoin switches. That is what I was planning to try but was just checking if there was a more efficient way to achieve the same thing.
