Changing VLAN Used for a SSID depending on the controller
  • 1.  Changing VLAN Used for a SSID depending on the controller
    Posted Oct 09, 2014 09:06 AM
    Dear all,
    We have a Wi-Fi architecture composed of two Controller 3400. One is master and the other one is local. The two controllers are on different places and the VLANs used are not the same on those two sites.
    We created two AP Groups with the same configuration: a SSID for employees based on 802.1X authentication. We create two SSID profiles where the only difference is the VLAN used.
    In order to backup the APs, we used the LMS IP and Backup LMS IP:
    - on the AP Group "Master" , LMS IP = Master and Backup LMS IP = Local (VLAN for SSID is number 20)
    - on the AP Group "Local", LMS IP = Local and Backup LMS IP = Master  (VLAN for SSID is number 40)
    As the VLANs used for the SSID are not the same, if the Local controller is down, its APs will be associated to the Master but the users who have an IP address in VLAN 40 won't be able to access to the network.
    We would like to know if it is possible to set the VLAN for one SSID depending on which controller the APs are associated ?
    Thanks in advance for any help !
    Thomas
    #3400
  • 2.  RE: Changing VLAN Used for a SSID depending on the controller
    Posted Oct 09, 2014 09:41 AM
    You need to create a NAME VLAN and associate each with VLAN that exist on the controller
  • 3.  RE: Changing VLAN Used for a SSID depending on the controller
    Posted Oct 09, 2014 09:44 AM
    Master controller:
    Local controller:
    VAP Config
  • 4.  RE: Changing VLAN Used for a SSID depending on the controller
    Posted Oct 09, 2014 09:50 AM
    Thank you very much, it works well !
  • 5.  RE: Changing VLAN Used for a SSID depending on the controller
    Posted Oct 09, 2014 09:48 AM
    EDITED: I was to slow
