Channel Bonding Symbols (+, -, S)
This thread has been viewed 105 times
  • 1.  Channel Bonding Symbols (+, -, S)
    Posted Jan 04, 2023 10:55 AM
    Hello All,
    Please correct me if I'm wrong, but in Mobility Conductor, when it says "Channel 40-" it means it's bonded with a lower channel. Similarly, 108+ would mean it's bonded with a higher channel.
    But when it comes to 6GHz channels, I'm now seeing a new symbol "S". What does the S represent? (For example, Channel 37S or Channel 149S). Is this more to just represent it's a 6GHz channel?
    Nate
  • 2.  RE: Channel Bonding Symbols (+, -, S)
    Posted Jan 04, 2023 11:25 AM
    This help? :
    +/- = 40 MHz
    E = 80 MHz
    S = 160 MHz
    E+E = 80 + 80 MHz (i.e. 36E+149E)
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Channel Bonding Symbols (+, -, S)
    Posted Jan 04, 2023 11:40 AM
    Hello Dustin,
    Thanks for the reply, that's exactly what I was looking for, thanks! The primary reason I was asking was that I see we have channels 37S and 149S on two APs. Why are these channels the primary channels listed? Instead of channel 47S and 143S (6E). What is the significance of the listed channel in MM?
    Nate
  • 4.  RE: Channel Bonding Symbols (+, -, S)
    Posted Nov 15, 2023 02:13 PM
    Thank you so much! I stucked in why only 20Mhz worked, and change to 40Mhz when I enabled 36+ ....
  • 5.  RE: Channel Bonding Symbols (+, -, S)
    Posted Jan 04, 2023 11:29 AM
    Is the S representing the Preferred Scanning Channel (PSC)?
  • 6.  RE: Channel Bonding Symbols (+, -, S)
    Posted Jan 04, 2023 11:35 AM
    No. S means that you are bonding 8 channels together into one 160Mhz wide channel. I would highly recommend turning off 160Mhz, and even 80Mhz wide bands to reduce your CCI. I always recommend using 20Mhz wide for 5Ghz radios, and bump up to 40Mhz if you need more throughput. Be aware though that when you bond channels, it gives you less to pick from when laying out your channel coverage. You want to try and avoid overlapping coverage of APs using the same channel.
    Dustin Burns
  • 7.  RE: Channel Bonding Symbols (+, -, S)
    Posted Jan 04, 2023 11:42 AM
    This is for 6Ghz channels. We are just doing testing in our environment right now (will likely run 80hz for 6Ghz in production).
  • 8.  RE: Channel Bonding Symbols (+, -, S)
    Posted Jan 04, 2023 11:59 AM
    Yes that makes sense :)
    Dustin Burns
  • 9.  RE: Channel Bonding Symbols (+, -, S)
    Posted Jan 04, 2023 11:31 AM
    Also, here is more information on the +/- notation:
    https://community.arubanetworks.com/browse/articles/blogviewer?blogkey=bf010c8b-7023-4336-ab40-355f40379e37
    Dustin Burns
  • 10.  RE: Channel Bonding Symbols (+, -, S)
    Posted Jan 05, 2023 04:10 AM
    You can see the flags used and a description, when you use the command
    show ap active
    https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/sh-ap-active.htm
    see the description of the flags in the example output - Channel Flags
