Channel Changes and Channel utilization
  • 1.  Channel Changes and Channel utilization
    Posted Nov 15, 2016 10:43 AM
    In my case, I discover that most of the AP managed have high utilization, more on 2.4GHz (>70%) radio ofcourse..while investigating, I found that there are groups of AP which use same channel and located really close to each other..
    Based on the wireless nature, I assume it will cause a broadcast storming and utilize the channel later on..but my concern is, why does not ARM change the channel..?
    If it is because of configuration, where can I configure the ARM..? or what is actually the criteria for channel change to occur..
    When same channel is used, there should be a drawback rigth..?
    When utilization is high, will it effect the user experience..?
  • 2.  RE: Channel Changes and Channel utilization
    Posted Nov 15, 2016 12:01 PM
    What type of APs do you have ?
    The end result depends on a lot of things :
    - How much the APs can hear each other based on proximity and power levels
    - How's ARM configured ?
    Get Outlook for iOS
