Channel Utilization Limits
  • 1.  Channel Utilization Limits
    Posted Apr 06, 2015 02:16 PM
    What is the best way to determine channel utilization on a radio. Is the QBSS the best way since its coming from the radio itself ? Different measuring tools can report different values, but most are in the ball park.
    What % is everyone using for maximum channel utilization for data - XX% ?
    What % is everyone using for maximum channel utilization for voice over wifi - XX% ?
    Thanks !
  • 2.  RE: Channel Utilization Limits
    Posted Apr 06, 2015 02:23 PM
    Hi George,
    Currently for our 2.4Ghz networks we use between 50-75% for campus style networks and 75%+ for public hotspots just because 2.4Ghz is overwhelmed and do not want to be triggered every 5 min.
    For 5ghz, we tend to set something lower something between 35-50%
    For voice, we haven't set anything up but i would assume in the areas of 35%-50%? Could be too low.
  • 3.  RE: Channel Utilization Limits
    Posted Apr 06, 2015 02:42 PM
    Thank you for the quick reply. Do you use the QBSS for your channel utilization measuring stick ?
  • 4.  RE: Channel Utilization Limits
    Posted Apr 06, 2015 02:52 PM
    Because we use Airwave to trigger us. We use currently the trigger for Channel Utilization only. No QBSS currently.
    It is configured as follows
    For 75 minutes if a channel is
    Time busy: 50%
    Interference: 50%
    Then alert us.
    This was obviously tweaked over and over and found that these values with this time period worked best for this environment.
    Hope this helps.
  • 5.  RE: Channel Utilization Limits
    Posted Apr 06, 2015 02:54 PM
    Isnt AirWave getting the Channel Util from the AP radio ?
  • 6.  RE: Channel Utilization Limits
    Posted Apr 06, 2015 03:00 PM
    I would assume so but documentation does not confirm this nor does it mention how it gets that value.
  • 7.  RE: Channel Utilization Limits
    Posted Apr 06, 2015 03:36 PM
    Thanks !
    Gstefanik,
    The QBSS is probably the most convenient method, when you are trying to troubleshoot voice, from the AP itself that is in the area, IF you are doing a packet capture at the same time.  The QBSS IE is by default off on Aruba controller-based APs, but is on by default on Aruba Instant APs when you designate a SSID as "voice".
    Airwave does collect channel utilization from Cisco and Aruba access points historically.  Aruba controllers needs to have AMON turned on to send this to Airwave.  This number is typically reported once per minute by the access point using the GUI and CLI of the controller.
    Some use the Channel Utilization numbers from a laptop spectrum analyzer, because it shows the number in realtime without  having to do a packet capture.   That number should be used in conjunction with the number seen on the AP itself, because some analyzers use the utilization numbers from the built in laptop adapter, so the mileage may vary.
    I want to say that channel utilization is situation-based and the ideal answer to "how much" for data and voip networks is always "less than you have right now".  I don't like to see 20% channel utilization when nothing should be going on (overnight).  Depending on the circumstances, it could shoot up into the 70% and your network can still function, depending on the application.
  • 8.  RE: Channel Utilization Limits
    Thanks !
    Gstefanik,
    The QBSS is probably the most convenient method, when you are trying to troubleshoot voice, from the AP itself that is in the area, IF you are doing a packet capture at the same time.  The QBSS IE is by default off on controller-based APs, but is on by default in Instant APs when you designate a SSID as "voice".
