Good day everyone,
Just want to ask what could probably the cause of not failing over to the standby module.
Below is an old log and it just happens again today. I had no access on the switch remotely so I opt to hard boot the switch.
Is there any way to identify if the management module is already faulty? I am very new to HP Procurve.
!LOGS
I 07/29/19 04:57:05 00063 system: xM2: Mgmt Module 1 went down: 07/29/19
04:56:47
M 07/29/19 04:57:05 00064 system: xM2: Software exception at alloc_free.c:495 --
in 'Inet
I 07/29/19 04:57:05 00266 system: xM2: Resetting Mgmt Module 1
W 07/29/19 04:57:05 00268 system: xM2: Mgmt Module 2 - Failover occured
I 07/29/19 04:57:05 00061 system: xM2: -----------------------------------------
I 07/29/19 04:57:05 02759 chassis: AM2: Savepower LED timer is OFF.
I 07/29/19 04:57:06 00937 chassis: AM2: Fabric 1 inserted
I 07/29/19 04:57:06 00937 chassis: AM2: Fabric 2 inserted
phmnlccent-sw-1# show version
Management Module 1: Standby
Image stamp: /sw/code/build/btm(K_15_03)
Feb 3 2011 21:05:19
K.15.03.0007
68
Boot Image: Primary
Management Module 2: Active
Feb 3 2011 21:05:19
K.15.03.0007
68
Boot Image: Primary
phmnlccent-sw-1# show redundancy detail
Slot Role Module Up Since State Since State
MM1 Standby 07/29/19 13:56:19 07/29/19 04:57:04 Standby
MM2 Active 07/29/19 13:58:23 07/29/19 04:57:03 Active
Failover Log:
Slot Role Time Reason
1 Active 07/29/19 04:56:47 Active Reset
1 Active 07/29/19 04:56:47 Crash
#J9091A#switch#HP#8212zl
