cheap certificate Clearpass
  • 1.  cheap certificate Clearpass
    Posted Sep 19, 2016 07:17 AM
    Hi Guys,
    I was using a Comodo SSL certificate to my Clearpass.
    Dou you know one that is cheaper? this one is $99 per year!
    Regards
  • 2.  RE: cheap certificate Clearpass
    Posted Sep 19, 2016 07:35 AM
    ssls.com is a good resource for finding certs.
  • 3.  RE: cheap certificate Clearpass
    Posted Sep 19, 2016 10:36 AM
    Hi
    What could be the right type of Certificate  choice on SSLs.com,  to do 802.1x authentication with Clearpass?
     I had instantSSL in Comodo and worked ok..
    Regards
  • 4.  RE: cheap certificate Clearpass
    Posted Sep 19, 2016 11:14 AM
    Any standard (non-wildcard) from a well-known CA will work.
  • 5.  RE: cheap certificate Clearpass
    Posted Sep 19, 2016 11:40 AM
    Sorry I am not certicates guy
    So a PossitiveSSL for 4.99/yr will work?
    Regards
  • 6.  RE: cheap certificate Clearpass
    Posted Sep 19, 2016 12:11 PM
    If it meets your organization's security requirements and policies, yes it will work.
