Check and apply SSID on ALL AP
  • 1.  Check and apply SSID on ALL AP
    Posted Dec 18, 2018 04:44 AM
    Hello everyone
    I created a ssid on the controller and i apply this ssid on a vap apply on a ap group
    but when i check on monitoring
    i see this ssid is not apply on all my AP
    I would like to apply this ssid on all my AP
    can you helpme  to this point
    Thanx for advance
  • 2.  RE: Check and apply SSID on ALL AP
    Posted Dec 18, 2018 04:50 AM
    If you apply the VAP to an AP group, all APs in that AP group will broadcast the SSID. Is it possible that some APs are a member of a different AP group? Or could it be possible that you have overwritten the config for the specific APs?
  • 3.  RE: Check and apply SSID on ALL AP
    Posted Dec 18, 2018 05:12 AM
    Hello
    tank for your answers
    how i can check if there are any problem with the broadcast of this ssid ?
  • 4.  RE: Check and apply SSID on ALL AP
    Posted Dec 20, 2018 06:57 AM
    llo
    I would like to know where is the configuration for assign this ssid or other ssid on ap ?
    on my case i have 4 ssid id and wheni chenk on  monitoring
    ssid a is affected on 10 ap
    ssid b is affected on 30 ap
    i dont have AP-goupe specific
    Thank by advance for your anwsers an your time to help me
    Best regards
  • 5.  RE: Check and apply SSID on ALL AP
    Posted Dec 20, 2018 08:12 AM
    Can you share your config or the output from the commands:
    show ap database
    show license-usage ap
  • 6.  RE: Check and apply SSID on ALL AP
    Posted Dec 21, 2018 04:33 AM
    Hello
    yes i can but it's a extrac of the ouput with hidden field the ap database
    Thnk for your beed back
    Berst regards
