Check for interface drops on WLAN controller
  • 1.  Check for interface drops on WLAN controller
    Posted Oct 29, 2015 05:41 PM
    Is there a command to see output drops on a WLAN controller due to contention on an uplink?  A Cisco switch would show it using the 'show int if#/#' command, but on an Aruba controller I don't see an 'output drop' count.  Just need to figure out how often some 1Gb links are getting overrun.
    Thanks.
  • 2.  RE: Check for interface drops on WLAN controller
    Posted Oct 29, 2015 06:21 PM
    The only option is to use the show port statistics but it only shows if there's any output or input error
  • 3.  RE: Check for interface drops on WLAN controller
    Posted Oct 29, 2015 06:34 PM
    Right, which is something different. Hard to believe this isn't available.
  • 4.  RE: Check for interface drops on WLAN controller
    Posted Oct 29, 2015 08:45 PM
    Thanks.
    If you have Airwave, it is monitoring the throughput on a controller, batched every 5 minutes, of course.
    If there is indeed congestion, in "show log system 100" you would see rebootstraps.
    Lastly, the back-of-the napkin size of an uplink should be one gigabit ethernet interface for each 100 access points.
