Comware
check interface block with stp via centreon
  • 1.  check interface block with stp via centreon
    Posted Dec 05, 2018 07:20 AM
    I configure on hp5130b switch from the stp
    conf:
    stp mode mstp
    stp region-configuration
    region-name
    revision-level 1
    instance 1 vlan 1 to 199
    instance 2 vlan 200 to 399
    active region-configuration
    stp instance 0 to 3 priority 12288
    stp bpdu-protection
    loopback-detection interval-time 5
    shutdown-interval 0
    interface range GigabitEthernet 1/0/1 to GigabitEthernet 1/0/48
    stp edged-port
    stp global enable
    to check if a port and block I use the command:
    display stp down-port
    I wanted to know if with my centreon-plugin monitoring tool if it was possible to check the interface block ?
    thank you
    #checkinterface
    #centreon-plugin
    #STP
    #spanning-tree
  • 2.  RE: check interface block with stp via centreon
    Posted Dec 10, 2018 03:36 AM
    Hi There,
    HPE Switches usually does send these traps and shows the port status w.r.t STP in some of the commonly used NMS tools such as IMC and Solardwinds.
    Not sure centreon-plugin monitoring tool, but if you are using the appropriate MIBs in the monitoring tool, then you should be getting it.
