Checking for registered guest device as part of wired mac auth connectivity
  • 1.  Checking for registered guest device as part of wired mac auth connectivity
    Posted Sep 04, 2018 10:30 AM
    Having got the ClearPass Guest device registration page set up and working, we now want to allow registered wired games consoles to be placed into a "games vlan" on a switch. I do this by assigning a "UoY Game Device" Role to the device and using this in the Enforcement policy.
    In my Service I've added [Guest Device Repository[ Local SQL DB to the Authorization section of my service and then added
    (Authorization:[Guest Device Repository]:AccountStatus  EQUALS  1
    AND  (Authorization:[Endpoints Repository]:Category  EQUALS  Game Console) ........
    to the Role Generation  section
    In Clearpass Guest ( see attached file you can see an AcountStatus set to 1
    However, in Policy Manager, for this devices Authenticatication I see
    Authorization:[Guest Device Repository]:AccountStatus0
    Authorization:[Guest Device Repository]:RemainingExpiration31535121
    Authorization:[Guest Device Repository]:SponsorNamecsrv107
    So one end says Acount Status=1 while the other says Account status=0
    A
  • 2.  RE: Checking for registered guest device as part of wired mac auth connectivity
    Posted Sep 04, 2018 11:02 AM
    Hmmm looking at the Policy Manager / Authentication/Sources/[Guest Device Repository]/ Attributes
    there is a Filter caled Authentication which returns Sponsor Name, Account expiration and  AccountStatus.
    The associated SQL is
    SELECT user_credential(password) AS User_Password,
    CASE WHEN enabled = FALSE THEN 225
    WHEN ((expire_time is not null AND expire_time <= now())) THEN 226
    ELSE 0
    END AS Account_Status, sponsor_name,
    CASE WHEN expire_time > now() THEN CAST(EXTRACT(epoch FROM (expire_time - NOW())) AS INTEGER)
    ELSE 0
    END AS remaining_expiration
    FROM tips_guest_users
    WHERE ((guest_type = 'DEVICE') AND (user_id = UPPER('%{Connection:Client-Mac-Address-Hyphen}'))
    So can't see how this gets back the Account Status entry for the guest device
  • 3.  RE: Checking for registered guest device as part of wired mac auth connectivity
    Posted Sep 05, 2018 05:51 AM
    Argh!!!!!
    So the key bit is
    ELSE 0
    So bascially if a clearpass guest device is enable and good to go, AccountStatus=0
    If the clearpass giuest device is disabled , AccountStatus = 225
    If  the device is expired  AccountStatus = 226
    Stared at this for ages till it finally clicked, was thinking that Account status should be 1 for true!
    So in Policy Manager I've got The following. If devic not registered, or is expired it end up in our portal else dropped into correct vlan
    42.(Authorization:[Guest Device Repository]:AccountStatus  EXISTS   )
    AND  (Authorization:[Guest Device Repository]:AccountStatus  EQUALS  0)
    UoY Games Device
