last person joined: 4 hours ago
Chrome Cert Error on Captive Portal Redirect
  • 1.  Chrome Cert Error on Captive Portal Redirect
    Posted Apr 14, 2015 02:14 PM
    I just noticed that Chrome on Android devices reports SSL error "err_cert_common_name_invalid" when you go to an HTTPS site and are redirected to the captive portal.  I don't often connect to our guest network so I just noticed this.  The Chrome error message indicates this may be the result of  'a Wi-Fi sign-in screen...'.  I'm wondering if this is a Chrome security enhancement that rolled out recently and if there is anyway to keep it from occuring while still using HTTPS on the captive portal?
  • 2.  RE: Chrome Cert Error on Captive Portal Redirect
    Posted Apr 14, 2015 02:18 PM
    Yes, they've enabled strict checking now. The only current solution is to either use http or use an interim http page and then do a meta redirect to the SSL page.
    Tim
  • 3.  RE: Chrome Cert Error on Captive Portal Redirect
    Posted Apr 14, 2015 02:21 PM
    Good suggestion.  I'll try the latter.  Thanks Tim!
