Chromecast 2 can't connect to WiFi
  • 1.  Chromecast 2 can't connect to WiFi
    Posted Feb 23, 2016 09:06 AM
    Hi there, since our customer has trouble connecting Chromecasts to their WiFi netwerk (using IAP215 on firmware 6.4.2.6.-4.1.1.7) we are testing at our own office.
    We used as well an IAP103 on same firmware, as well on latest 6.4.4.3.-4.2.2.1.
    Unfortunately we can't manage to make the Chromecast 2 work on Aruba Instant network. We have tried a OPEN and secured WPA2 WiFi network - with Services as DNLA enabled and disabled.
    Does anyone understand and or can help with a solution? I have attached screenshot (they are in dutch but I put most importatn translation on it).
    edit: ps I can ee in Instant the Chromecast has an IP, but on screen it stil shows 'trying to connect to network'.
  • 2.  RE: Chromecast 2 can't connect to WiFi
    Posted Feb 23, 2016 10:32 AM
    If you have broadcast filtering disabled on your SSIDs, it should work without Airgroup.  Please try that.
     The only two reasons why you would need to use Airgroup Are:
    - You have broadcast filtering set to "all" or "arp" on your SSIDS
    - Your clients are not on the same subnet as your DLNA devices.
  • 3.  RE: Chromecast 2 can't connect to WiFi
    Posted Jun 17, 2016 10:32 PM
    I am also having the same problem with a Chromecast 2 and multiple versions of Aruba IAP-205 firmware including the latest early release. Does anyone at the Aruba Lab have a chromecast to try? I am on a typical WPA2 network, multicast filtering disabled...
    David
  • 4.  RE: Chromecast 2 can't connect to WiFi
    Posted Oct 06, 2016 02:09 PM
    Disabling broadcast filtering allowed my Chromecast 2 to operate normally when connected to IAP 205.  I can now successfully cast from devices connected to the same SSID.
  • 5.  RE: Chromecast 2 can't connect to WiFi
    Posted Oct 06, 2016 02:54 PM
    For me having any of the roaming features  (802.11r,k,v) enabled caused the Chromecast to not associate. I had to created a separate SSID profile without those enabled in order to get the Chromecast to connect.
    David
