hello can you help me to tell me as chromecast enabled on my controller Aruba6000??? thanks.
Are you running AOS 6.4?
no, is the 6.3
You'll need to upgrade to AOS 6.4 to use Chromecast with AirGroup.
Your only other option would be to ensure that all the devices are in the same VLAN and that drop bcast/mcast is disabled. (THIS IS NOT RECOMMENDED)
ok I'll update it and then what is the procedure for setting chromecast?
Enable AirGroup and then enable the DIAL and Googlecast AirGroup services. (Configuration > Advanced Services > AirGroup)
ok thanks I'll try and update itany questions you might ask?Thanks in advance
