chromecast with controller
  • 1.  chromecast with controller
    Posted Jun 04, 2020 09:27 AM
    hey all
    i want to know how to enable chromecast on aruba controller ver. 8.6 i checked air group on mc but didn't know how to configure it actually , so hope to advise me about its configuration or if its should configure cli not gui
    thanks
  • 2.  RE: chromecast with controller
    Posted Jun 06, 2020 06:58 AM
    enable the Airgroup on Controller to use Chromecast in network
    Configuration > Services > AirGroup
  • 3.  RE: chromecast with controller
    Posted Jun 06, 2020 10:22 AM
    hi dinusha ,
    i did it already but is there any configuration i should do to show chromecast was enable or someting should configure it by cli not in gui
  • 4.  RE: chromecast with controller
    Posted Jun 06, 2020 10:25 AM
    did you enable mDNS
  • 5.  RE: chromecast with controller
    Posted Jun 06, 2020 12:01 PM
    Actually no i tried to enable it but i didn't find it on gui i have mc ver.8.6
  • 6.  RE: chromecast with controller
    Posted Jun 06, 2020 09:16 PM
    i also tried to enable mdns and dlna from cli but it appears that i should do it from airgroupprofile and when i try to enter it says cant do it you should enable it from MM node !! i need to activate airgroup from MC cause customer didn't have MM , is that possible ?
  • 7.  RE: chromecast with controller
    Posted Jun 07, 2020 12:48 AM
    on the left side pane,  selects the managed node. then try to enable.
