Hi all,
We have Guest controller and local controler.We are connecting local controler to guest controller via Tunnel.
we have seperate DHCP pool for guest access and separte DHCP server configerade for the guest Ip pool and It is connected to Guest controller.
when clints requesting for the IP, it will get from DHCP server
Now Our issue is various local Clints which connected to differnt Local controller and not got IP address.We checked the DHCP server and other thinks realted to dhcp evrythinks works fine and rebotted the server also.It did not works well.
After rebooting the controller ,every clints got the Ip address and works fine
Regards
ANU M
