last person joined: 9 hours ago
Cisco 3560CX-12port Issue with Voice VLAN
  • 1.  Cisco 3560CX-12port Issue with Voice VLAN
    Posted Sep 19, 2019 12:05 PM
    I am having a problem with our phones.  They don't work when plugged into a port controlled by clearpass 6.8.2.XXXXXXX.
    1)  They are Avaya phones
    2)  They get their 802.1Q tag for VLAN 42 from the DHCP Server
    3)  They don't get a DHCP lease.  Nothing seems to be going over VLAN42 from the phone?
    I used the Solution Exchange to get my IBNS 2.0 configuration (Attached, Sanitized).  I have attached a picture of my Enforcement Profile, the two policies, and the service.  I have profiling setup and on ports that are not controlled by ClearPass, phones are working perfectly!  802.1x is working perfectly on the ports as well and assigning the correct vlan!  802.1X is working through the phone port too!  The ports that are controlled by clearpass, whenever I send a VLAN for the phone, i get an error that I can't use the same VLAN that the Voice VLAN is set to?    Also attached I have my configuration for how my 3 different ports on the switch look like.  Port 11 works fine, I modified port 10 to not use the ACL, and port 9 uses the ACL.  Both 9 and 10 are not working with my phone.  (Should I send it a different VLAN?)   I'm at a loss here.  Attached are my 3 ports and template below:
    template ClearPass-Template
    dot1x pae authenticator
    spanning-tree portfast edge
    switchport access vlan 9
    switchport mode access
    switchport voice vlan 42
    mab
    access-session closed
    access-session port-control auto
    service-policy type control subscriber ClearPass-Policy
    interface GigabitEthernet1/0/9
    ip access-group IPV4-PRE-AUTH-ACL in
    srr-queue bandwidth share 1 30 35 5
    mls qos trust cos
    auto qos trust
    source template ClearPass-Template
    interface GigabitEthernet1/0/10
    mls qos trust cos
    auto qos trust
    interface GigabitEthernet1/0/11
    priority-queue out
    mls qos trust cos
    auto qos trust
  • 2.  RE: Cisco 3560CX-12port Issue with Voice VLAN
    Posted Sep 25, 2019 12:13 AM
    Send "device-traffic-class=voice" rather than VLAN for VOIP. Refer pg 134 of https://community.arubanetworks.com/t5/Security/ClearPass-Solution-Guide-Wired-Policy-Enforcement/td-p/298161
  • 3.  RE: Cisco 3560CX-12port Issue with Voice VLAN
    Posted Sep 26, 2019 09:32 AM
    This fixed the issue!  Thank you!  Attached is a screenshot showing what it looks like.EnforcementProfile-UIU_Cisco_Voice.jpg
