Wired Intelligent Edge
Cisco 9200L stack to 2930F - LACP port-channel issue
This thread has been viewed 24 times
  • 1.  Cisco 9200L stack to 2930F - LACP port-channel issue
    Posted Feb 11, 2021 12:58 PM
    Hi Guys,
    I wonder if anybody had anything similar and can help me to resolve the issue.
    I have Cisco 9200L stack 16.12.4 and Aruba switch 2930F.
    Connected with SFP/fiber.
    Cisco keeps telling me
    Feb 11 03:28:26.051: %ETC-5-L3DONTBNDL2: Gi1/1/1 suspended: LACP currently not enabled on the remote port.
    Feb 11 03:28:26.815: %ETC-5-L3DONTBNDL2: Gi2/1/1 suspended: LACP currently not enabled on the remote port.
    The interfaces on the Aruba side simply Link Down.
    Spanning tree - MST on both sides.
    Fiber cables multimode and checked.
    SFPs in use: GLC-LH-SMD and 1000-Base-SX
    Ports configuration below:
    Cisco
    interface GigabitEthernet1/1/1
    switchport trunk allowed vlan 2300-2316
    switchport mode trunk
    speed nonegotiate
    channel-group 1 mode active
    interface GigabitEthernet2/1/1
    speed nonegotiate
    interface Port-channel1
    Aruba
    interface 51
       speed-duplex 1000-full
       untagged vlan 1
       trunk trk2 lacp
    interface 52
       untagged vlan 1
       trunk trk2 lacp
    interface Trk2
       tagged vlan 2300-2316
       untagged vlan 1
       spanning-tree priority 4
       exit
    Aruba switch output:
    Load Balancing Method: L3-based (default)
    Port | Name Type | Group Type
    51 | ===Name=== 1000SX | Trk2 LACP
    52 | ===Name=== 1000SX | Trk2 LACP
    LACP Trunk Port LACP Admin Oper
    Port Enabled Group Status Partner Status Key Key
    51 Active Trk2 Down No Success 0 533
    52 Active Trk2 Down No Success 0 533
    Thanks in advance,
    Paul​
    Paul Ze
  • 2.  RE: Cisco 9200L stack to 2930F - LACP port-channel issue
    MVP GURU
    Posted Feb 11, 2021 04:26 PM
    What do you have on Aruba log ?
    why you have disable auto negotiation ?
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Cisco 9200L stack to 2930F - LACP port-channel issue
    Posted Feb 11, 2021 05:00 PM
    Try this
    configuration of TRUNK Cisco ports between switches:
    switchport trunk encapsulation dot1q
    switchport nonegotiate
    spanning-tree link-type point-to-point
    maxime FUHRMANN
  • 4.  RE: Cisco 9200L stack to 2930F - LACP port-channel issue
    Posted Feb 11, 2021 07:18 PM
    Hi Maxime,
    I just found out.
    The SFPs have different wavelength. :(
    The devil is really in the details.
    Kind regards,
    Paul
  • 5.  RE: Cisco 9200L stack to 2930F - LACP port-channel issue
    Posted Feb 12, 2021 02:24 AM
    Great! Bravo ;)
    maxime FUHRMANN
  • 6.  RE: Cisco 9200L stack to 2930F - LACP port-channel issue
    MVP GURU
    Posted Feb 12, 2021 08:08 PM
    Yeah...never interconnect a Long Haul transceiver (LH/LX = operates on standard single-mode fiber-optic link spanning up to 10 km and up to 550 m on any multimode fibers) with a Short Range (SR/SX = operates in multi-mode fiber-optic link spanning generally less than 300/500 meters) transceiver...central wavelengths are necessarily different (850 nm vs 1310/1550 nm)!
    Read the good Aruba AOS-Switch and AOS-CX Transceiver Guide (Edition 10) to understand essential differences about various transceivers.
    Davide Poletto
  • 7.  RE: Cisco 9200L stack to 2930F - LACP port-channel issue
    Posted Feb 11, 2021 06:00 PM
    Hi Alagoutte,
    Aruba log is empty.
    No messages related to the connection at all.
    I tried with and without auto negotiation.
    I even tried a simple trunk connection between the switches.
    Aruba side stil Link-Down.
    I wonder if there's a way to check the SFPs?
    May the GLC-LH-SMD and 1000-Base-SX aren't compatible?
    Kind regards,
    Paul
