Cisco ACI to Aruba 3400 Controller possibly causing packet loss
  • 1.  Cisco ACI to Aruba 3400 Controller possibly causing packet loss
    Posted Oct 20, 2016 01:16 PM
    We have recently migrated a set of our Aruba 3400 Controllers from traditional Rtr/Switch topology to Cisco ACI.  The last couple months we have noticed off occurrences dealing with Packet Loss from End Users either connected to APs or RAPs.  We have reloaded the 3400 Controllers a couple times and this seems to resolve the issue but only temporarily.  I am not 100% convinced we have the ACI Interfaces to Aruba Interfaces configured correctly which is causing our problems.
    I also want to point out I have 2 Aruba 3400s at this location configured the same with the exception of Interface IPs.
    Aruba Configuration:
    SETUP:  Master / Local Configuration
    MODEL: Aruba3400
    VERSION: 6.3.1.14
    ROLE:  Local Controller
    vlan 30  - All Wireless User Subnet (AP & RAP)
    vlan 60  - Management Network
    vlan 168 - Guest Wireless User Subnet
    vlan 567 - Mobile User Subnet (MDM)
    vlan 966 - Public Network
    interface gigabitethernet 1/0
            description "GE1/0"
            trusted
            trusted vlan 1-4094
            switchport mode trunk
            switchport access vlan 30
            switchport trunk allowed vlan 30,60,168,567
    interface gigabitethernet 1/2
            description "GE1/2"
            trusted
            trusted vlan 1-4094
            switchport access vlan 966
    interface vlan 60
            ip address xx.xx.xx.95 255.255.255.0
            no ip routing
            bcmc-optimization
    interface vlan 30
            no ip routing
            bcmc-optimization
    interface vlan 966
            ip address xx.xx.xx.53 255.255.255.0
            no ip routing
            bcmc-optimization
    interface vlan 567
            no ip routing
            bcmc-optimization
    interface vlan 168
            no ip routing
            bcmc-optimization
    GE 1/0 is up, line protocol is up
    Hardware is Gigabit Ethernet, address is 00:0B:86:6F:26:0D (bia 00:0B:86:6F:26:0D)
    Description: GE1/0 (RJ45 Connector)
    Encapsulation ARPA, loopback not set
    Configured: Duplex ( AUTO ), speed ( AUTO )
    Negotiated: Duplex (Full), speed (1000 Mbps)
    MTU 1500 bytes, BW is 1000 Mbit
    Last clearing of "show interface" counters 23 day 12 hr 40 min 39 sec
    link status last changed 23 day 12 hr 36 min 48 sec
        1744773237 packets input, 1376375032868 bytes
        Received 18338884 broadcasts, 0 runts, 0 giants, 0 throttles
        0 input error bytes, 0 CRC, 0 frame
        15641428 multicast, 1726434353 unicast
        1683401939 packets output, 1352014369653 bytes
        0 output errors bytes, 0 deferred
        0 collisions, 0 late collisions, 0 throttles
    CISCO ACI Configuration
    VERSION - 12.0.2g
    All Vlans are setup one to one with End Point Groups (EPG) and Bridge Domains (BD).  All EPGs are in a single VRF, Domain, Application Profile, and Tenant.
    ACI Interface to Controller Configuration
          EPG30/BD30
        L2 Unknown Unicast = Flood
        L3 Unknown Multicast = Flood
        Multi Destination Flooding = Flood in BD
        ARP Flooding = Flood
        Encapsulation = Vlan-30
        No Contracts Used
    Ethernet1/7 is up
    admin state is up, Dedicated Interface
      Port description is CORSTLSDR3400-01:Fa1/0 INT
      Hardware: 1000/10000/auto Ethernet, address: f8c2.88b5.6a3f (bia f8c2.88b5.6a3f)
      MTU 9000 bytes, BW 1000000 Kbit, DLY 1 usec
      reliability 255/255, txload 1/255, rxload 1/255
      Encapsulation ARPA, medium is broadcast
      Port mode is trunk
      full-duplex, 1000 Mb/s, media type is 1G
      Beacon is turned off
      Auto-Negotiation is turned on
      Input flow-control is off, output flow-control is off
      Auto-mdix is turned off
      Rate mode is dedicated
      Switchport monitor is off
      EtherType is 0x8100
      EEE (efficient-ethernet) : n/a
      Last link flapped 03w23d
      Last clearing of "show interface" counters 00:47:05
      4 interface resets
      30 seconds input rate 8151544 bits/sec, 1117 packets/sec
      30 seconds output rate 7811080 bits/sec, 1122 packets/sec
      Load-Interval #2: 5 minute (300 seconds)
        input rate 14173696 bps, 1810 pps; output rate 14368184 bps, 1851 pps
      RX
        6524296 unicast packets  4110 multicast packets  10048 broadcast packets
        6538454 input packets  5751643352 bytes
        0 jumbo packets  0 storm suppression bytes
        0 runts  0 giants  0 CRC  0 no buffer
        0 input error  0 short frame  0 overrun   0 underrun  0 ignored
        0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
        0 input with dribble  0 input discard
        0 Rx pause
      TX
        6283754 unicast packets  21733 multicast packets  3047 broadcast packets
        6308534 output packets  5677787433 bytes
        0 jumbo packets
        0 output error  0 collision  0 deferred  0 late collision
        0 lost carrier  0 no carrier  0 babble  0 output discard
        0 Tx pause
    Could the way we have ACI configured be causing an issue with the trunk to the Aruba Controller?
  • 2.  RE: Cisco ACI to Aruba 3400 Controller possibly causing packet loss
    Posted Oct 20, 2016 05:25 PM
    I honestly do not see anything wrong with the configuration. The unwritten rule is that either it does work or it does not work. The question is, what else may be happening in your network or do you have the interface statistics of the ACI or the logs.tar from the controller when it is happening?
    Is the controller itself hard to reach at the time?
  • 3.  RE: Cisco ACI to Aruba 3400 Controller possibly causing packet loss
    Posted Oct 24, 2016 02:36 PM
    I do not seem to notice an issue accessing the Controller during this time.
    I have attempted to send a log.tar but it appears to be too large for email.  Do you have another way to receive files?
    Daniel
