CISCO and ClearPass "could not determine role id for user clearpass"
  • 1.  CISCO and ClearPass "could not determine role id for user clearpass"
    Posted Apr 16, 2014 06:02 PM
    i have implemented a CleraPass (with guest self-provisioning) with a CISCO WLC.
    I used the integration guide of CISCO WLC and Amigopod.
    I have created the service like if the controiller was an aruba controller.
    The only difference is that instead Aruba:ESSID-Name i have use Connection: SSID.
    When the guest try to connect to SSID him is redirected to Captive Portal, he put the required information but when click on "Register" he receive this error:
    I have try to manually create a guest user, so he is able to login.
    do you have any idea?
    Thanks in advance.
    Best regards
    Andrea
  • 2.  RE: CISCO and ClearPass "could not determine role id for user clearpass"
    Posted Apr 16, 2014 11:37 PM
    Packet-capture on Clear pass server can tell you what radius attribute coming in to server especially on radius-access request.
    Clear pass may drop and not return if we dont see the attribute config.
  • 3.  RE: CISCO and ClearPass "could not determine role id for user clearpass"
    Posted Apr 18, 2014 08:46 AM
    I have tried to remake the guese self registration page and now all works fine.
    Best regards
    Andrea
