Cisco flex 7510 controller to use Clearpass guest web auth landing page
  • 1.  Cisco flex 7510 controller to use Clearpass guest web auth landing page
    Posted Sep 24, 2015 11:32 AM
    Hi
    We have a mixed wireless environment, we have both Cisco and Aruba wifi infrustructure. For guest web authentication, currently Cisco controller (flex 7510
    ) using internal landing page ( within 7510 controller), the SSID that serve guest access is local switching,  we are trying to switch the guest web
    authentication landing page from internal (( with Cisco controller)to external ( clearpass). my test failed in both http and https redirecting to clearpass
    page, the landing page won't show up on client device.  the preauth ACL on Cisco WLC is as below:
         1 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0           17     0-65535    53-53     Any Permit           0
         2 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0           17    53-53        0-65535  Any Permit           0
         3 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0            1     0-65535     0-65535  Any Permit         103
         4 Any         0.0.0.0/0.0.0.0               10.0.6.60/255.255.255.255    6     0-65535   443-443    Any Permit           0
         5 Any       10.0.6.60/255.255.255.255         0.0.0.0/0.0.0.0            6   443-443       0-65535  Any Permit           0
         6 Any         0.0.0.0/0.0.0.0               10.0.6.60/255.255.255.255    6     0-65535    80-80     Any Permit          50
         7 Any       10.0.6.60/255.255.255.255         0.0.0.0/0.0.0.0            6    80-80        0-65535  Any Permit           0
         8 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0          Any     0-65535     0-65535  Any   Deny      181008
    The same guest SSID works fine if using internal landing page with same clearpass server as radius server.
    The same clearpass landing page works fine for client associated to Aruba APs.
    Any ideas or suggestions?
  • 2.  RE: Cisco flex 7510 controller to use Clearpass guest web auth landing page
    Posted Sep 24, 2015 11:37 AM
    I don't think external captive portal is supported in FlexConnect mode.
  • 3.  RE: Cisco flex 7510 controller to use Clearpass guest web auth landing page
    Posted Sep 24, 2015 11:48 AM
    Thank you very much Tim.
    Did u have any documents about it ? If yes can you please send me a link. I checked Cisco web site and opend a TAC case , nowhere mentioned this?
  • 4.  RE: Cisco flex 7510 controller to use Clearpass guest web auth landing page
    Posted Sep 24, 2015 11:52 AM
    Looks like support was added in 7.2.110. What version are you running?
    http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/112042-technote-wlc-00.html
  • 5.  RE: Cisco flex 7510 controller to use Clearpass guest web auth landing page
    Posted Sep 24, 2015 11:56 AM
    8.0.110.0, yes, looks like supported.
  • 6.  RE: Cisco flex 7510 controller to use Clearpass guest web auth landing page
    Posted Sep 24, 2015 11:57 AM
    I would post in parallel on Cisco's forums.
  • 7.  RE: Cisco flex 7510 controller to use Clearpass guest web auth landing page
    Posted Oct 16, 2015 05:09 PM
    I'm working on my deployment now. I have a Cisco 5520 WLC, running 8.1.x code, in FlexConnect mode and ClearPass 6.5.3. I'm just getting started but have found this document that may help.
    http://www.cisco.com/c/en/us/support/docs/wireless/flex-7500-series-wireless-controllers/113605-ewa-flex-guide-00.html
    Patrick
  • 8.  RE: Cisco flex 7510 controller to use Clearpass guest web auth landing page
    Posted Oct 19, 2015 11:48 AM
    Thanks patrick.
    This works.
    I also followed a document using ISE as external login server which explained similar configuration.
  • 9.  RE: Cisco flex 7510 controller to use Clearpass guest web auth landing page
    Posted Aug 24, 2017 10:18 AM
    So you guys got a Flexconnect AP with local switching to work with Clearpass Guest?
    Can you share a bit more detail?
