Comware
CISCO IP phone on HP 5130-24G-P​oE
  • 1.  CISCO IP phone on HP 5130-24G-P​oE
    Posted Jun 13, 2016 06:00 AM
    We trying to configure cisco IP phone7940 (cdp only) on HP 5130-48G-PoE+-4SFP+ (370W) EI JG937A (HP Comware Software, Version 7.1.045, Release 3109P14
    The phone cannot take an IP adress by our DHCP, but we have not this problem with our computer
    From interface Giga 1 to 7 : we are unable to take an IP adress on phone, but lldp seems to works !
     version 7.1.045, Release 3109P14
     sysname SW-5130-NP
     clock timezone TH minus 07:00:00
     clock protocol none
     telnet server enable
     undo voice-vlan security enable
     voice-vlan mac-address b4a4-e300-0000 mask ffff-ff00-0000 description CISCO ip PHONE 7940G
     voice-vlan mac-address c062-6b00-0000 mask ffff-ff00-0000 description CISCO ip PHONE 7940G
     voice-vlan mac-address 0015-fa00-0000 mask ffff-ff00-0000 description CISCO ip PHONE 7940G
     voice-vlan mac-address 0016-4600-0000 mask ffff-ff00-0000 description CISCO ip PHONE 7940G
     irf mac-address persistent timer
     irf auto-update enable
     undo irf link-delay
     irf member 1 priority 1
     dhcp snooping enable
     lldp global enable
     lldp compliance cdp
     password-recovery enable
     poe legacy enable pse 4
    vlan 1
    vlan 92
    vlan 102
    vlan 190 to 203
    vlan 222
    vlan 500
    vlan 520
    interface NULL0
    interface Vlan-interface1
     ip address 10.99.1.102 255.255.255.0
    interface Vlan-interface500
     ip address 10.10.10.102 255.255.255.0
    interface GigabitEthernet1/0/1
     description PC
     port link-type hybrid
     port hybrid vlan 1 102 untagged
     port hybrid pvid vlan 102
     voice-vlan 92 enable
     stp edged-port
     lldp compliance admin-status cdp txrx
     cdp voice-vlan 92
     ip verify source ip-address
     poe enable
     dhcp snooping binding record
    interface Ten-GigabitEthernet1/0/49
     description uplink
     port link-type trunk
     port trunk permit vlan all
     dhcp snooping trust
    Thanks for your help :)
  • 2.  RE: CISCO IP phone on HP 5130-24G-P​oE
    Posted Jun 13, 2016 10:53 AM
    Please try port link-type trunk for you Cisco Phone_PC connection, such as:
     description Cisco VoIP Phone_PC_connected
     undo port trunk permit vlan 1
     port trunk permit vlan 92 102
     port trunk pvid vlan 102
     undo voice vlan mode auto
    Main difference in your config is that, here PC Data traffic is untagged. Voice vlan is tagged vlan.
    Having LLDP-MED/CDPv2 working, you don't nee d to use OUI anymore.
    Here is the example reference about LLDP_MED/CDPv2:
    http://ipcisco.com/neighbour-discovery-protocols-part-5-lldp-med/
    Michal
  • 3.  RE: CISCO IP phone on HP 5130-24G-P​oE
    Posted Jun 13, 2016 11:54 PM
    Thanks for the info
     version 7.1.045, Release 3111P03
     sysname FL.1
     clock protocol none
     voice-vlan aging 43200
     voice-vlan track lldp
     voice-vlan mac-address aca0-1600-0000 mask ffff-ff00-0000 description CISCO ip PHONE 7940G
     voice-vlan mac-address 001b-5300-0000 mask ffff-ff00-0000 description CISCO ip PHONE 7940G
     voice-vlan mac-address 0021-a000-0000 mask ffff-ff00-0000 description CISCO ip PHONE 7940G
     voice-vlan mac-address 18ef-6300-0000 mask ffff-ff00-0000 description CISCO ip PHONE 7940G
     undo irf link-delay
     lldp global enable
     lldp compliance cdp
     loopback-detection global enable vlan 1 to 4094
     loopback-detection global action shutdown
     loopback-detection interval-time 300
    interface GigabitEthernet1/0/2
     undo port hybrid vlan 1
     port hybrid vlan 95 tagged
     port hybrid vlan 105 untagged
     port hybrid pvid vlan 105
     undo voice-vlan mode auto
     voice-vlan 95 enable
     stp edged-port
     poe enable
     this is  present config   I will try port  hybird to port  trunk
  • 4.  RE: CISCO IP phone on HP 5130-24G-P​oE
    Posted Jun 20, 2016 02:35 PM
    Did you have a chance to check how it works with trunk port?
    Br,
    Michal
  • 5.  RE: CISCO IP phone on HP 5130-24G-P​oE
    Posted Jun 20, 2016 10:34 PM
     stp edged-port
     poe enable
    this is  present config   Use it without problems  Symptoms to watch for a while
    Thank You
  • 6.  RE: CISCO IP phone on HP 5130-24G-P​oE
    Posted Jul 07, 2016 05:49 PM
    I have a CP-7940G version 1 and it will not even power on. What was the exact model of the 7940G phone you used? CP-7940G? Was it version 1 or version 2? Do you have the phone's firmware by chance? Also, what PSE firmware were you running?
    I have a 7941G-GE V02 and it powers on just fine.
    On another note, per this comment I required the below line to be added to my port config in order for the phone to register on the right VLAN.
    • lldp tlv-enable med-tlv network-policy 95
  • 7.  RE: CISCO IP phone on HP 5130-24G-P​oE
    Posted Jul 08, 2016 04:43 AM
    Not sure about additional LLDP-specific line required but the fact is Comware just "emulates" CDPv2 in/out packets. So this is the case only for switches different than CISCO vendor. without native CDPv2 protocol implemented.
    A am right?
    Michal
  • 8.  RE: CISCO IP phone on HP 5130-24G-P​oE
    Posted Jul 08, 2016 10:40 AM
    Ok, here is the final explanation from HPE R&D Team:
    HP 5130EI Switch - Voice VLAN TLV-MED not Accepted by Cisco Phone mmr_kc-0124501
    Michal
