Cisco IP Phone through AP-205H
  • 1.  Cisco IP Phone through AP-205H
    Posted Apr 13, 2016 06:56 AM
    Has anybody ever set-up a Cisco IP phone to work through one of the Ethernet ports on an AP-205H??
    We have an education customer who would like to install AP-205H in all rooms in the halls but each room only has a single cable and running more cables is not an option. Currently this single cable is used to connect to a Cisco IP phone and the user plugs their device in to the phone.
    If we install AP-205H's can the IP phone be connected to the PoE out port (presumably in bridge mode with the port set-up as a trunk) and it function as it does now?
  • 2.  RE: Cisco IP Phone through AP-205H
    Posted Apr 23, 2016 06:22 AM
    This can be done, but the AP205H must have an 802.3at switch powering it to be able to power the phone up to 10 watts if you only have a single cable:
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=17326
