Network Management
Cisco MSTP Config with Aruba
  • 1.  Cisco MSTP Config with Aruba
    Posted Jul 25, 2024 11:53 AM
    Hello, we have switched over to almost all HP Aruba CX series switches which are running MSTP by default with the Core Switch set as the root.  We have a couple Cisco 3850 switches we cannot replace due to budget.  I would like these to run MSTP instead of Rapid-STP for consistency and we're seeing numerous topology changes, which we think is due to running both.
    I have tried the commands below on the Cisco.  It comes back online after the changing it to MSTP but reports the root switch as itself.  Is there something I'm missing to do this properly or is this correct and expected behavior?
    Cisco config:
    config t
    spanning-tree mst configuration
    instance 0 vlan 1-4094
    name 88:25:10:e9:a6:00
    revision 0
    show pending
    exit
    spanning-tree mode mst
    end
    show spanning-tree
    MST0
      Spanning tree enabled protocol mstp
      Root ID    Priority    32768
                 Address     0c97.5f4c.2200
                 Cost        20000
                 Port        1 (GigabitEthernet1/0/1)
                 Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
      Bridge ID  Priority    32768  (priority 32768 sys-id-ext 0)
                 Address     8890.8dde.e980
    show spanning-tree mst
    ##### MST0    vlans mapped:   1-4094
    Bridge        address 8890.8dde.e980  priority      32768 (32768 sysid 0)
    Root          address 0c97.5f4c.2200  priority      32768 (32768 sysid 0)
                  port    Gi1/0/1         path cost     20000
    Regional Root this switch
    Operational   hello time 2 , forward delay 15, max age 20, txholdcount 6
    Configured    hello time 2 , forward delay 15, max age 20, max hops    20
    Aruba config output from core switch:
    show spanning-tree mst-config
    MST configuration information
       MST config ID        : 88:25:10:e9:a6:00
       MST config revision  : 0
       MST config digest    : AC36177F50283CD4B83821D8AB26DE62
       Number of instances  : 0
    Instance ID     Member VLANs
    0               1-4094
    show span
    Spanning tree status      : Enabled Protocol: MSTP
    MST0
      Root ID    Priority   : 0
                 MAC-Address: 88:25:10:e9:a6:00
                 This bridge is the root
                 Hello time(in seconds):2  Max Age(in seconds):20
                 Forward Delay(in seconds):15
      Bridge ID  Priority  : 0
