Cisco RADIUS Cannot select appropriate authentication method
  • 1.  Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 09:03 AM
    I setup Cisco switch (3560 12.2) to authenticate with Clearpass and seeing 'Authentication failure' and  'RADIUS Cannot select appropriate authentication method' in Access Tracker. I am using service 'MSCHAPV2-wired' with MSCHAP auth , tried to add few more , didn't help.. appreciate advice
    Cisco-C3560#test aaa group netlab netlab1 n3w@y!n new-code
    User rejected
    Cisco-C3560#sh ver | i Version
    Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
  • 2.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 09:12 AM
    Do you have MSCHAP as the authentication method in your service?
    Tim
  • 3.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 09:20 AM
    Yes MSCHAP is my first Authentication Method
  • 4.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 09:36 AM
    Can you please share the switch config ?
  • 5.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 09:41 AM
    Sure, this is aaaa part of cisco switch config:
    aaa new-model
    aaa group server radius netlab
    server-private 10.95.2.201 auth-port 1812 acct-port 1813 key 7 xxx
    dot1x system-auth-control
    radius-server attribute 6 on-for-login-auth
    radius-server attribute 8 include-in-access-req
    aaa authentication dot1x default group netlab
  • 6.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 12:03 PM
    How's your interface configured ?
    Have you been able to authenticate successfully using 802.1X against AD with your wireless setup ?
  • 7.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 12:07 PM
    so fa I've tested  wired only from cisco switch using 'test' command
    #test aaa group netlab netlab1 password new-code
    User rejected
  • 8.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 12:17 PM
    Are you using AD as an authentication source?
  • 9.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 12:20 PM
    no AD, just local Claerpass user
  • 10.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 12:57 PM
    User rejected
    Niuk,
    Please try the ASE solution here:  https://ase.arubanetworks.com/solutions/id/93
  • 11.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 09:38 AM
    Hi
    We have found that the most stable version of 12.2 IOS code is 12.2(55)SE9. We've found issues in many others...
    Regards
    Chris
  • 12.  RE: Cisco RADIUS Cannot select appropriate authentication method
    Posted Feb 18, 2015 10:42 AM
    I tried on C3560C Version 15.2(2)E1, same thing Clearpass Access Tracker says 'Cannot select appropriate authentication method'
