Cisco switch 2950
  • 1.  Cisco switch 2950
    Posted May 29, 2017 10:46 AM
    Dear, If I have a cisco switch 2950 which does not support COA
    How can I configure dynamic vlan assignement based on healthy check result
    THANKS
  • 2.  RE: Cisco switch 2950
    Posted May 29, 2017 10:47 AM
    You'd need to use Agent Bounce.
  • 3.  RE: Cisco switch 2950
    Posted May 29, 2017 05:01 PM
    Dear,
    If i used port bounce will that force the end user to change its vlan and ip based on healthy check result if its connected to 2950 switch while there is no aruba controller only cisco switches??
  • 4.  RE: Cisco switch 2950
    Posted May 29, 2017 05:06 PM
    Agent Bounce will cause the same behavior but from the client side
  • 5.  RE: Cisco switch 2950
    Posted May 29, 2017 05:27 PM
    Dear,
    Could explain more as i didnt get what u say in the last message
  • 6.  RE: Cisco switch 2950
  • 7.  RE: Cisco switch 2950
    Posted May 29, 2017 05:38 PM
    Dear,
    I'll try and tell you back
    I have two more questions:
    1- if there are VDI solution zero client; will that work normal with clearpass?
    2- End users dont change their healthy check automatic I have to click the retry button to change the healthy check status.. so I configured session time-out to 60 seconds but i got too many logs in the clearpass. Each 30 (half period) seconds all the 2000 end users will send logs to the clearpass.. so is there any thing to do to make agent send logs only when the status change
    Too many thanks bro
  • 8.  RE: Cisco switch 2950
    Posted Jun 01, 2017 09:02 PM
    Please add more details to those two questions.
  • 9.  RE: Cisco switch 2950
