Cisco Switch Config for Cisco VoIP/ClearPass
  • 1.  Cisco Switch Config for Cisco VoIP/ClearPass
    Posted Sep 15, 2015 04:34 PM
    Does anyone have a working Cisco switch config that uses Cisco VoIP phones authenticated through ClearPass MAC auth?  I need not only the interface config, but also the AAA if possible.
    Thank you in advance.
  • 2.  RE: Cisco Switch Config for Cisco VoIP/ClearPass
    Posted Sep 15, 2015 04:57 PM
    GLOBAL CONFIG:
    aaa new-model
    aaa authorization network default local group radius
    radius-server vsa send authentication
    radius-server host <CPPM IP> auth-port 1812 acct-port 1813 key <KEY>
    aaa authentication dot1x default group radius local
    aaa authorization auth-proxy default group radius
    aaa server radius dynamic-author
    client <CPPM IP> server-key <KEY>
    INTERFACE CONFIG:
    interface <Interface ID>
    switchport access vlan <Data VLAN>
    switchport mode access
    authentication port-control auto
    mab
    IF you want you can send the Voice VLAN after a successfull authentication
  • 3.  RE: Cisco Switch Config for Cisco VoIP/ClearPass
    Posted Sep 21, 2015 11:51 AM
    Thank you kindly, Victor.
  • 4.  RE: Cisco Switch Config for Cisco VoIP/ClearPass
    Posted Jan 23, 2017 10:57 PM
    Buena noches victor tengo el mismo ambiente queremos autenticar los telefonos con mac (MAB) y las computadoras conectadas al telefono y autenticarlas con 802.1x  , tengo la siguiente conf en el sw
    dot1x system-auth-control
    lldp run
    interface FastEthernet0/22
    switchport access vlan 100
    switchport voice vlan 2
    authentication host-mode multi-domain to authentication host-mode multi-auth
    authentication order dot1x mab
    authentication priority dot1x mab
    authentication periodic
    authentication timer reauthenticate server
    mab
    dot1x pae authenticator
    dot1x timeout server-timeout 30
    dot1x timeout tx-period 3
    dot1x timeout supp-timeout 20
    spanning-tree portfast
    radius-server host CPPM
    radius-server host CPPM auth-port 1812 key aruba123
    radius-server host CPPM acct-port 1813 key aruba123
    radius-server host CPPM auth-port 1812 acct-port 1813 key aruba123
    radius-server retry method reorder
    radius-server timeout 15
    radius-server deadtime 15
    Crees que este correcta la configuracion.
    Saludos.
  • 5.  RE: Cisco Switch Config for Cisco VoIP/ClearPass
    Posted Jan 24, 2017 11:47 AM
    Se ve bien la configuracion
