Cisco Switch Downloadable ACL example and troubleshooting
  • 1.  Cisco Switch Downloadable ACL example and troubleshooting
    Posted Oct 01, 2013 04:50 PM
    All,
    I'm trying to put together a quarantine VLAN that does the following:
    1. I want to allow DHCP
    2. I want to allow DNS
    3. I want to allow traffic to three Clearpass IPs so the OnGuard client can communicate a posture change to a healthy status
    4. I want to block traffic to two of their internal subnets
    5. The last line will allow Internet access in the mean time
    Here's ideally what this would look like as an enforcement policy being sent as a Cisco-IP-Downloadable-ACL (185):
    permit udp any eq bootpc any eq bootps
    permit udp any eq domain
    permit ip any 10.10.100.70 0.0.0.0
    permit ip any 10.10.100.69 0.0.0.0
    permit ip any 10.10.100.68 0.0.0.0
    deny ip any 192.168.0.0 0.0.255.255
    deny ip any 10.0.0.0 0.0.0.255
    permit ip any any
    Unfortunately, I can't get the above to work correctly. I'm able to do the following Cisco-IP-Downloadable-ACL (185):
    permit ip any any
    The strange thing is that I'm still able to access http resources and ping in the 10/8 subnet, even with the above. Here's the switch details:
    Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
    Any help would definitely be appreciated – thanks!
    -Mike
  • 2.  RE: Cisco Switch Downloadable ACL example and troubleshooting
    Posted Oct 01, 2013 06:09 PM
    Mike,
    Here is an example of my onguard and my guest it might give you a starting point. Ill try to replicate what your doing and see if I can come up with what you need.
     deny   tcp any host 10.60.1.xxx
     deny   tcp any host 10.60.2.xxx
     permit tcp any any
    permit tcp any any eq 80
    permit tcp any any eq 443
    permit tcp any any eq 23
    permit tcp any any eq 25
    permit tcp any any eq 110
    permit tcp any any eq 587
    permit tcp any any eq 21
    permit tcp any any eq 20
    http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080bb1929.shtml
  • 3.  RE: Cisco Switch Downloadable ACL example and troubleshooting
    Posted Oct 01, 2013 07:02 PM
    Troy,
    As always, super helpful! I'll give the below a try tomorrow afternoon and update this thread.
    permit
  • 4.  RE: Cisco Switch Downloadable ACL example and troubleshooting
    Posted Oct 01, 2013 07:07 PM
    Troy,
    I also was just shown that I jacked up the wildcard mask on the /8... which explains why some of the IPs in that range were working. That line should read:
    deny ip any 10.0.0.0 0.255.255.255
    Thanks!
    -Mike
  • 5.  RE: Cisco Switch Downloadable ACL example and troubleshooting
    Posted Oct 02, 2013 01:40 AM
    Nice catch,
    Let me know how it turns out.
  • 6.  RE: Cisco Switch Downloadable ACL example and troubleshooting
    Posted Oct 02, 2013 11:00 AM
    Hi Troy,
    I was able to get the following working:
    permit udp any host 10.10.100.22
    permit udp any host 10.10.100.25
    permit ip any host 10.10.100.70
    permit ip any host 10.10.100.69
    permit ip any host 10.10.100.68
    permit ip any any
    I wasn't able to get any of the "eq" commands working on the switch. The UDP packets referenced in the first two lines will work for DHCP and DNS. Granted, it's not as granular as I would like, but it's definitely a start.
    Btw, do you know if it's possible to send an ACL name to a Cisco switch, similar how you can send a filter ID to a Juniper switch? It might be a better idea to just send an ACL name to the switch and then get granular at that level. I haven't set that up before and was wondering if you had?
    Thanks!
    -Mike
  • 7.  RE: Cisco Switch Downloadable ACL example and troubleshooting
    Posted Oct 02, 2013 11:08 AM
    Yes you can send a named. Here is an example where Im calling a named acl with a url redirect.
  • 8.  RE: Cisco Switch Downloadable ACL example and troubleshooting
  • 9.  RE: Cisco Switch Downloadable ACL example and troubleshooting
    Posted Oct 03, 2013 11:03 PM
    Hi Troy,
    Thanks for passing along that link, if others on the forum haven't seen it. I think your example of a real-world dACL example should be included in that guide. I've been using that guide to setup Cisco switches with Clearpass without issue. It's the dACL portion that is definitely lacking.
    Thanks for the help!
    -Mike
