Cisco URL Redirect
This thread has been viewed 62 times
  • 1.  Cisco URL Redirect
    Posted Sep 17, 2014 11:16 PM
    Is there a way to send a Cisco switch a URL redirect to a CPPM captive portal from an enforcement profile?
    The idea here is if a computer connects to port configured to use 802.1x and not using EAP-TLS, then we will force the client to go to a Captive Portal and register. I see Cisco Downloadable ACLs but I don't see how to tell the device to use the Captive Portal.
    Thanks in advance for any help
  • 2.  RE: Cisco URL Redirect
    Posted Sep 18, 2014 12:03 AM
    Yes this is possible.
    What type of switch do you have ? and OS version do you have installed ?
    It would look something like this:
    And you need to enabled ip http and create an ACL that looks like this:
    ip access-list extended Onboard_ACL
     deny   tcp any host 192.168.1.102
     permit tcp any any
  • 3.  RE: Cisco URL Redirect
    Posted Sep 18, 2014 12:28 AM
    Thank you for the response.
    Its a 3750 on the latest IOS, not sure of the exact version
  • 4.  RE: Cisco URL Redirect
    Posted Sep 18, 2014 12:30 AM
    That should work
  • 5.  RE: Cisco URL Redirect
    Posted Sep 18, 2014 12:54 PM
    The ACL should allow for access to the CPPM server but how do you force the client to the captive portal, dynamically?
  • 6.  RE: Cisco URL Redirect
    Posted Sep 18, 2014 01:40 PM
    Within your enforcement policy you need to define the condition and based on that condition you will enforce an action (enforcement profile)
     Here's an example that I use for my wireless 802.1X:
    In this scenario I want non-domain devices to get onboarded (SmartPhones, Windows, Mac OSX , etc..) and that have authenticated successfully using PEAP authentication
    And then will allow to get on the network without getting onboarded if it authenticates using EAP-TLS:
    This doesnt exactly matches your case but I wanted to give you an idea of what you could do and how flexible ClearPass can be.
    Key things to keep in mind:
    - If you want to make decision based on device type you need to add ClearPass as a DHCP relay under your SVIs
    - Add the endpoint database as an authorization source
    - And enabled the following to be use as roles:
    So when the device authenticates you can use this as tips roles to make decisions :
  • 7.  RE: Cisco URL Redirect
    Posted Sep 18, 2014 01:51 PM
    Thank you, I understand that part but how do you send the Cisco switch the URL redirect? I haven't been able to find how to send that.
    I'm using a Cisco Downloadable Role and I see the AV-Pair where I can use a URL-redirect but I'm not certain that is what I'm looking for.
    Andy Clelland
    ACMP, ACCP
  • 8.  RE: Cisco URL Redirect
    Posted Sep 18, 2014 02:15 PM
    In the enforcement profile
  • 9.  RE: Cisco URL Redirect
    Posted Aug 25, 2016 01:28 PM
    I'm trying this exact thing, and cannot get it to work.
    I have an enforcement profile that successfully sends an DACL to the switch, however whenever I attempt to add the Cisco AV-Pair url-redirect the DACL fails to download and the port then enters and odd state
    This is on a Cisco 2960 running 15.2(4)E lan base.
    Are there any known caveats for using the url-redirect functionality?  It seems as though a lot of the documentation is surrounding MAB and not 802.1x authenticaiton.
    I'm trying to use the url-redirect for ONGUARD to point users to CPPM for agent download when the are unhealthy.
    Thanks!
                Interface:  FastEthernet0/18
              MAC Address:  xxxx.xxxx.xxxx
             IPv6 Address:  Unknown
             IPv4 Address:  Unknown
                User-Name:  xxxxxx
                   Status:  Unauthorized
                   Domain:  DATA
           Oper host mode:  single-host
         Oper control dir:  both
          Session timeout:  N/A
          Restart timeout:  N/A
        Common Session ID:  0AC0400E000000A145E716DB
          Acct Session ID:  Unknown
                   Handle:  0xEC000022
           Current Policy:  POLICY_Fa0/18
    Local Policies:
           	Service Template: DEFAULT_LINKSEC_POLICY_SHOULD_SECURE (priority 150)
    Resultant Policies:
    Method status list:
           Method           State
           dot1x            Authc Success
  • 10.  RE: Cisco URL Redirect
    Posted Oct 06, 2016 05:08 PM
    I'm trying the same thing (sending the url-redirect via Radius:Cisco:Cisco-AVPair to a Cisco ASA (9.2.2.4).... the AV-Pair attributes don't get to the ASA.
    The Cisco command:
    sh vpn-sessiondb details anyconnect
    doesn't show the attribute for that session and the client doesn't get redirected.
  • 11.  RE: Cisco URL Redirect
    Posted Aug 20, 2021 03:17 AM
    Hi Victor,
    I am also facing same problem. I have Cisco 2960 Switch trying to send redirect url to the switch running IOS version 15.2(7) E2 but its not working.
    I have asked Aruba TAC about this issue but he is  unable to assist because its a switch switch.  According to him the config is correct
    Please advise how you fixed it.
    Varun Sharma
  • 12.  RE: Cisco URL Redirect
    Posted Jun 11, 2018 08:27 PM
    Thanks Victor. I can see your Cisco AV-pair for captive portal redirect uses HTTPS. Does you wired client complain about any untrusted certificates. My wired client complains about a untrusted certificate which happens to be the certificate on the switch.
  • 13.  RE: Cisco URL Redirect
    Posted Aug 20, 2021 03:19 AM
    Hi Victor,
    Varun Sharma
  • 14.  RE: Cisco URL Redirect
    Posted Jan 05, 2024 12:03 AM
    Dear @Victor Fabian,
    is this still valid sir ? i used cisco c9200 switch with IOS-XE Version 17.9.1r [FC8] but still not triggering to open pop up captive portal,
    kindly need advise, thanks
    BR,
    Hudaya
