CIsco WAP321 and clearpass guest registration
  • 1.  CIsco WAP321 and clearpass guest registration
    Posted May 18, 2016 11:10 AM
    HI, i have a CISCO unmaneged AP (WAP321), that have the following feature, can I integrated this witrh clearpass guest solution.
    Interfaces10/100/1000 BASE-T autosensing (RJ45)
    Powering Options802.3af Ethernet Switch, Cisco SB-PWR-INJ-12V-xx power Injector or Local Power Supply (SB-PWR-12V-xx)
    FrequencySelectable Band 2.4 GHz or 5 GHz ((not concurrent)
    Wireless802.11n, 3x2 multiple input multiple output (MIMO)
    Operating modesAccess Point mode, WDS bridging, Client Bridge mode
    VLAN supportYes
    Number of VLANs1 management VLAN plus 4 VLANs for SSID
    Multiple SSIDs8
    802.1X supplicantYes
    SSID to VLAN mappingYes
    Auto channel selectionYes
    Spanning treeYes
    Load balancingYes
    IPv6Yes
    Layer 2802.1Q-based VLANS, 4 active VLANS plus 1 management VLAN
    Access controlYes, management access control list (ACL) plus MAC ACL
    Rogue access point detectionYes
    Quality of service (QoS)Wi-Fi Multimedia and Traffic Specification (WMM TSPEC)
    Maximum AP’s per cluster8
    Active clients per cluster80
    Management protocolsWeb browser, Simple Network Management Protocol (SNMP) v3, Bonjour
    HTTP redirectYes
    Wireless isolationWireless isolation between clients
    RoamingYes
    Wi-Fi Multimedia (WMM)Yes, with unscheduled automatic power save
    Regards
    Andrea Acampa
  • 2.  RE: CIsco WAP321 and clearpass guest registration
    Posted May 23, 2016 11:03 AM
    Based on....
    HTTP redirectYes
    I would say yes. Check the appropriate software guide for the WAP to determine how to do a web authentication to an external server. This should provide what is required.
