Cisco Wired Guest Webauth Service Question
  • 1.  Cisco Wired Guest Webauth Service Question
    Posted Apr 12, 2017 02:11 PM
    Hi:
    I'm trying to get wired captive portal guest access working with a Cisco switch.
    I realize this needs two services. The initial mac-auth service is working fine... returning the redirect-url and redirect-url-acl to the switch.
    But I'm having problems with the captive portal.
    We are browsing to http://<clearpassIP>/guest/ciscowiredguest.php?mac=11:22:33:44:55:66, and that brings up the login form.
    But when I enter a known guest account and click submit, Access Tracker shows a REJECT. The message is: "Failed to classify request to service" The autentication attempt comes in with just the user name - no other info.
    I have an active service of type "Web-based Authentication" and the rule is:
    Host - Checktype - MATCHES_ANY - Authentication.
    Is there some other rule I need to make this work?
    Is there a special configuration needed for the captive portal login page?
    Am I correct in understanding that the switch is not involved in this part of the transaction (until it succeeds, of course, at which point it gets a CoA Terminate session)?
    Thanks.
  • 2.  RE: Cisco Wired Guest Webauth Service Question
    Posted Apr 12, 2017 02:24 PM
    How do you have your Captive Portal Page login method configured ?
  • 3.  RE: Cisco Wired Guest Webauth Service Question
    Posted Apr 12, 2017 02:37 PM
    I've tried several different options...
    right now it's set to:
    Vendor Settings: Cisco Systems
    Login method: Server Initiated - Change of Authorization (RFC 3576) sent to controller.
    What should it be set to?
  • 4.  RE: Cisco Wired Guest Webauth Service Question
    Posted Apr 12, 2017 02:42 PM
    That is correct. Do you have a WEBAUTH service?
  • 5.  RE: Cisco Wired Guest Webauth Service Question
    Posted Apr 12, 2017 02:51 PM
    Yes.
    Here's a screenshot of how it's configured.
  • 6.  RE: Cisco Wired Guest Webauth Service Question
    Posted Apr 12, 2017 02:54 PM
    Hm, definitely should be matching that.
    Please post a few screenshots of the access tracker request tabs.
  • 7.  RE: Cisco Wired Guest Webauth Service Question
    Posted Apr 14, 2017 01:38 PM
    Thanks for all your help.
    I found the Webauth service problems: I had inadvertantly selected a Pre-Auth-Check parameter in the guest login page.
    Once I set that to "None-no extra checks will be made," the webauth service is being hit successfully.
    Thank you.
  • 8.  RE: Cisco Wired Guest Webauth Service Question
    Posted May 17, 2017 03:23 PM
    Do you have any writeup that you can share? Looking at doing the same and don't want to reinvent the wheel.
    TIA.
  • 9.  RE: Cisco Wired Guest Webauth Service Question
    Posted May 17, 2017 03:25 PM
    There will be a full wired solution guide available in the next two weeks.
  • 10.  RE: Cisco Wired Guest Webauth Service Question
    Posted May 30, 2017 04:23 PM
    Any updates on this :) ?
  • 11.  RE: Cisco Wired Guest Webauth Service Question
    Posted May 30, 2017 05:55 PM
    Friday.
  • 12.  RE: Cisco Wired Guest Webauth Service Question
