Cisco WLC
  • 1.  Cisco WLC
    Posted Aug 06, 2013 06:28 PM
    Anyone doing mac-auth with an open SSID on a CiSCO WLC with a captive portal on Mac failure. We have a Cisco WLC.
    We can get mac-auth working and authentication with the local web auth service but when we combine both so we have mac filter with a web policy on Mac failure. It doesn't work well on iOS devices. Windows pcs work okay but iPads and iPhones are not user friendly.
    All works well on aruba controller.
  • 2.  RE: Cisco WLC
    Posted Aug 07, 2013 08:10 AM
    IOS devices behave differently for the captive portal authentication after you upgrade to IOS 6.0.  they will try communicating to apple.com and will expect a message "success" over html.
    MY 2 cents :)
    But if its something thats not working in Cisco WLC, i recomend to contact CISCO tac.
  • 3.  RE: Cisco WLC
    Posted Aug 08, 2013 02:36 PM
    I sent you a PM but thought I'd post here for others as well.
    vkumaar is correct, they try to do a lookup on www.apple.com, but I'm blocking Web Traffic to anything except my CP-Guest Server, so I believe its simply a DNS lookup and ICMP response to the clients.  You can do a couple things, you can add an IP Address for Apple's Website into your Pre-Authentication ACL, or, My suggestion, would be to add the following lines to the same ACL:
    Doing this took care of all my Captive Portal Apple issues.
    I know, with the old Amigopod, you could add a "/landing.php?/" to the front of your registration page link, and it would Bypass the Apple portion of the captive portal.  I have not tried it lately so I do not know if that is still being used with the newer versions of Clearpass Guest.  When I move to Clearpass 6.2 in the coming months, I might look at it again.  Any developers know for sure if this still is the case with CP 6.2 and up?
