Cisco WLC 7.2.110.0 onboard/guest issues
  • 1.  Cisco WLC 7.2.110.0 onboard/guest issues
    Posted Mar 26, 2013 05:38 PM
    Running into 2 issues with cisco wlc v7.2.110.0
    1-      Add switch IP. To have iOS automatically reconnect after OnBoarding, you have to pass the switch IP back. On the aruba controller you can do this in the captive portal config. I have not seen a way to do this in cisco.
    2-      URL whitelisting – since cisco does basic IP based ACL’s, how can we whitelist apple and google play urls? I know we can put in the current IP’s but they could change any time
    How have you guys tackled these in the past?
  • 2.  RE: Cisco WLC 7.2.110.0 onboard/guest issues
    Posted Apr 04, 2013 05:04 AM
    1.  You cannot do this with Cisco
    2.  With Cisco WLC 7.2 and above you can use CNA Bypass:  http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/wlan/config_wlan_chapter_010001.html
  • 3.  RE: Cisco WLC 7.2.110.0 onboard/guest issues
    Posted Oct 04, 2013 09:53 AM
    Hello guys,
    This is the same concern I'm facing with CISCO WLC.
    Is it posible to include www.appleiphonecell, captive.portal.com URLs in cisco ACL or whitelist it? because we cannot use bypass Apple CNA as it is affecting other WLAN's behaviour in our environment.
    Please help if you find a solution for this issue!
    Bharani..
