Cisco WLC 7.4
  • 1.  Cisco WLC 7.4
    Posted Feb 05, 2013 06:49 AM
    Is it possible to manage/monitor Cisco controllers running 7.4 code ?
  • 2.  RE: Cisco WLC 7.4
    Posted Feb 05, 2013 04:46 PM
    No specific support has been added for Cisco controllers on firmware 7.4.x.x.  The last tested version was 7.3.101.0 in AMP 7.6.
    If you're running AMP 7.6 and are seeing anything not working properly, it's worth it to open a support case.
    If you're asking as a prior measure before upgrading your controller firmware, typically monitoring will be available.  Management of new features may not be included (these would be worth filing as feature requests in the Ideas Portal on the support site for future improvement).
  • 3.  RE: Cisco WLC 7.4
    Posted Feb 05, 2013 05:58 PM
    Ok, thanks Rob
  • 4.  RE: Cisco WLC 7.4
    Posted Jan 24, 2014 11:00 AM
    Can documentation get updated because as of 7.7.8 it says the following:
