CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
This thread has been viewed 46 times
  • 1.  CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    Posted Mar 01, 2021 11:39 AM
    Hello Community,
    Please, anyone could share with me a document, guide, diagram or photograph about the kit:
        P/N: Q8N47A
        Description: CKIT-OD-COV-GL Covers and Glands
    Henderson Iturralde
  • 2.  RE: CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    MVP GURU
    Posted Mar 01, 2021 11:45 AM
    Are you talking about this piece?
    Dustin Burns
  • 3.  RE: CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    Posted Mar 01, 2021 11:51 AM
    Hello Dustin.
    It's about this part (IRIS capture).
    I couldn't find info about this one in AFP, Airheads and other sources.
    Henderson Iturralde
  • 4.  RE: CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    MVP GURU
    Posted Mar 01, 2021 11:52 AM
    I think this is because they are replacement parts. I don't know of any online document for the parts replacement kits other than what comes with the hardware (if it even does).
    Dustin Burns
  • 5.  RE: CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    MVP GURU
    Posted Mar 01, 2021 11:48 AM
    Sorry wrong screenshot lol. This?
    Dustin Burns
  • 6.  RE: CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    MVP GURU
    Posted Mar 01, 2021 11:49 AM
    If so, then this is found in the AP installation guides. See section below:
    Dustin Burns
  • 7.  RE: CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    Posted Mar 01, 2021 01:46 PM
    Hello Dustin,
    Thank you.
    I reviewed the installation guide (https://support.hpe.com/hpesc/public/docDisplay?docId=a00104591en_us) but there's not a reference that the cable gland in the graphic correspond to the P/N Q8N47A.
    Then, this option in IRIS would be the spare one (the first paragraph in your capture indicates that the cable gland is shipped with the AP).
    Best Regards,
    Henderson Iturralde
  • 8.  RE: CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    MVP GURU
    Posted Mar 01, 2021 02:16 PM
    It is shipped with the AP (cover and glands 2 sizes). Q8N47A would be replacement or spare parts for the 2 cable sizes for the gland, and the cover if it gets cracked/damaged.
    Dustin Burns
  • 9.  RE: CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    Posted Mar 01, 2021 03:51 PM
    Great, thanks a lot,
    Henderson Iturralde
  • 10.  RE: CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    Posted Mar 04, 2021 02:46 PM
    This is what comes with that kit: 5 M20 Ethernet glands with M20 covers, 1 M25 fiber port cover, 2 USB port covers, and 2 ground lugs
    Jerrod Howard
  • 11.  RE: CKIT-OD-COV-GL Covers and Glands P/N Q8N47A
    Posted Jan 24, 2022 01:15 PM
    Thank you Jerrod!
    I require some replacements (due included ones being used elsewhere)  Was having a difficult time understanding what was included in the sku/kit
    Cheers,
    ~Merlin
    Merlin Mott
