Hello All,
Does someone have a technical document/note about the new Clarity feature inside AirWave?
I try to know how Clarity takes his measurement. For example for DHCP, how does it calculate the delay? Does the controller look for the DHCP Discover from a Client then measure the time till the DHCP ACK or the DHCP offer? How it is measured?
Just would like to know how it works exactly to be sure to evaluate correctly those points during troubleshooting.
Many thanks in advance for sharing :-)
