Clarity Upgrade from local file
  • 1.  Clarity Upgrade from local file
    Posted Jan 17, 2018 03:20 PM
    Hello Everyone,
    Wondering if anyone has upgrade Clarity VM server from a local file.
    If so, Can anyone share the steps to acomplish this task?
    We are unable to update using the RPM Package therefore I am looking for other solutions.
    Perhaps the steps may be similar to the ones in the following post
    https://community.arubanetworks.com/t5/Monitoring-Management-Location/How-to-upload-a-file-on-Airwave-8-2-4-from-Windows-machine/ta-p/303145
    Thank you,
  • 2.  RE: Clarity Upgrade from local file
    Posted Jan 18, 2018 04:21 AM
    I'm not sure why you can't upgrade using the RPM, as that is the 'local file' upgrade method.
    From the Clarity Engine User Guide:
    How to Update the RPM Package
    Before you upgrade the RPM package using the rpm command, you must first use yum to resolve a dependency on tunctl:
    # yum install tunctl
    # rpm -Uf CE-1.0.0.1-62118.x86_64.rpm
    I just tried the upgrade on my Clarity Engine and that worked like this:
    First I uploaded the upgrade file CE-1.0.0.1-62118.x86_64.rpm to my Clarity Engine. You can use WinSCP for that, and login with username root and the password that you set for that.
    Then use SSH (Putty), or the (VMWare) console, to get shell access as root and run the commands from the User Guide:
     % ssh root@192.168.31.15
    root@192.168.31.15's password:
    [root@clarity ~]# ls
    anaconda-ks.cfg  CE-1.0.0.1-62118.x86_64.rpm  install.log  install.log.syslog
    [root@clarity ~]# yum install tunctl
    Loaded plugins: fastestmirror, security
    Setting up Install Process
    Determining fastest mirrors
    epel/metalink        |  15 kB     00:0
     * base: mirror.atlanticmetro.net
     * epel: fedora-epel.mirrors.tds.net
     * extras: mirror.fileplanet.com
     * updates: mirror.fileplanet.com
    base        | 3.7 kB     00:0
    base/primary_db        | 4.7 MB     00:0
    epel        | 4.7 kB     00:0
    epel/primary_db        | 6.0 MB     00:0
    extras        | 3.4 kB     00:0
    extras/primary_db        |  29 kB     00:0
    updates        | 3.4 kB     00:0
    updates/primary_db        | 5.8 MB     00:0
    Resolving Dependencies
    --> Running transaction check
    ---> Package tunctl.x86_64 0:1.5-3.el6 will be installed
    --> Finished Dependency Resolution
    Dependencies Resolved
     Package                                        Arch                                           Version                                           Repository
    Installing:
     tunctl                                         x86_64                                         1.5-3.el6                                         base
    Transaction Summary
    Install       1 Package(s)
    Total download size: 9.2 k
    Installed size: 9.5 k
    Is this ok [y/N]: y
    Downloading Packages:
    tunctl-1.5-3.el6.x86_64.rpm        | 9.2 kB     00:0
    Running rpm_check_debug
    Running Transaction Test
    Transaction Test Succeeded
    Running Transaction
      Installing : tunctl-1.5-3.el6.x86_64
      Verifying  : tunctl-1.5-3.el6.x86_64
    Installed:
    Complete!
    [root@clarity ~]# rpm -Uf CE-1.0.0.1-62118.x86_64.rpm
    [root@clarity ~]# rpm -q CE
    If this does not help, please let us know at what point you get stuck. Another option is to just re-deploy Clarity Engine as there is little configuration to do on the Engine itself.
  • 3.  RE: Clarity Upgrade from local file
    Posted Sep 05, 2018 10:02 AM
    Thank you fo rthe explanation and the step by step.
