Clean-Up Flash
This thread has been viewed 88 times
  • 1.  Clean-Up Flash
    Posted Dec 13, 2012 03:24 PM
    Hello -
    We are struggling to upgrade a controller - we are out of space in flash.
    I can delete files from DISK but I cannot see anyway to clean up Flash - show storage is the best I can find but are there CLI or web interface commands to get into flash to clean it up? Do we just keep rebooting the device untill flash frees up some space?
    Need to get this upgrade done to get my controllers online
  • 2.  RE: Clean-Up Flash
    Posted Dec 13, 2012 06:15 PM
    how much space you got on flash?
    Can you please do
    show memory
    And also
    Show storage
    To see the output?
  • 3.  RE: Clean-Up Flash
    Posted Dec 14, 2012 02:43 PM
    show memory
    Memory (Kb): total: 387692, used: 288396, free: 99296
    show storage
    Filesystem Size Used Available Use% Mounted on
    /dev/mtdblock11 156.0M 128.8M 27.2M 83% /flash
    none 300.0M 1.7M 298.3M 1% /tmp
    /dev/mtdblock9 50.0M 24.6M 25.4M 49% /mnt/img0
    /dev/mtdblock10 50.0M 24.3M 25.7M 49% /mnt/img1
  • 4.  RE: Clean-Up Flash
    Posted Dec 14, 2012 04:39 PM
    Okay
    do a show boot
    and it will show you the configuration file is using right now....
    You should be able to delete old coniguration files, at least just delete the older ones...
    As reference for you i remenber i read this a while ago... i searched in the airheads forum for you as reference.
    Here is it
    http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Which-files-can-I-delete-in-my-A200/td-p/11046
    Hope this helps you
  • 5.  RE: Clean-Up Flash
    Posted Dec 14, 2012 04:46 PM
    Also take in mind that
    You should have at least 40 MB of free memory available for an upgrade using the CLI, or at least 60 MB of free memory available for an upgrade using the WebUI.
    Cheers
    Carlos
  • 6.  RE: Clean-Up Flash
    Posted Dec 19, 2012 08:43 AM
    Where you able to delete old configuration files and do the upgrade?
