last person joined: 10 hours ago
Cleapass CoA to Extreme Switches
  • 1.  Cleapass CoA to Extreme Switches
    Posted Jan 10, 2019 02:46 PM
    Hi, experts
    Does anyone know how to configure and innitiate a CoA to one of Extreme Summit x440 and Summit x450 switches?
    I need to configure OnGuard in ClearPass for verification of the health status of the devices, and CoA is indispensable for this.
    Thank you
  • 2.  RE: Cleapass CoA to Extreme Switches
    Posted Jan 10, 2019 03:10 PM
    I assume you mean a Disconnect, not a CoA?
    Try using just the standrad IETF Disconnect Message that is built in.
  • 3.  RE: Cleapass CoA to Extreme Switches
    Posted Jan 10, 2019 03:17 PM
    Hi, Tim
    Sí, me refería a un "port bounce".
    The standard IETF Disconnect Message that is built in ClearPass?
    Thanks for your reply
  • 4.  RE: Cleapass CoA to Extreme Switches
    Posted Jan 10, 2019 03:21 PM
    I don’t believe Extreme has a Port Bounce CoA.
  • 5.  RE: Cleapass CoA to Extreme Switches
    Posted Jan 10, 2019 03:27 PM
    So how I could do works the OnGuard for the change of Vlans?
    Regards
  • 6.  RE: Cleapass CoA to Extreme Switches
    Posted Jan 10, 2019 03:28 PM
    You’d have to use the Agent Bounce.
  • 7.  RE: Cleapass CoA to Extreme Switches
    Posted Jan 10, 2019 03:39 PM
    Thanks for your reply, Tim
    What do I need to configure on the ClearPass side for this to work only with Extreme switches?
  • 8.  RE: Cleapass CoA to Extreme Switches
    Posted Jan 11, 2019 04:19 AM
    In the agent enforcement set bounce client to true for each health status. this will force the onguard agent to perform a bounce from the client side (after a posture status change), not from the switch.
    Then the client will reauthenticate with the new health status to your dot1x service, there you can assign a new vlan enforcement, for example user vlan when posture status == healthy, and quarantaine vlan when posture status is unhealthy.
  • 9.  RE: Cleapass CoA to Extreme Switches
    Posted Jan 11, 2019 09:51 AM
    Thank for your reply, Fabian.
    I'm going to test your solution and post the results.
    Regards
