Network Management
Clear AMP swarm old entries?
  • 1.  Clear AMP swarm old entries?
    Posted Sep 12, 2018 05:45 AM
    Hi All,
    I have problem with Airwave. In my setup I use 3 clusters that were once added to Airwave, then removed, groups deleted.
    Now, when I want do add these 3 clusters to Airwave I get this behavior:
    - only 1 cluster is detected in New Devices
    - but ALL 3 clusters IAPs appear in amp logs with "PSK based authentication: swarm is not approved in Airwave."
    I suspect, problem is caused by some old entries in amp DBs. How to view and delete them?
    I don't use whitelists, allow all option is enabled.
    All network communication between amp and clusters is opened.
    I don't want to start from scratch (have some WLCs that I want to stay in amp).
    Please advice what am I doing wrong?
  • 2.  RE: Clear AMP swarm old entries?
    Posted Sep 12, 2018 06:21 AM
    Attaching VC logs:
    # show log ap-debug
    01:14:30  awc[2495]: awc_login: awc_init
    01:14:30  awc[2495]: awc_init_connection: 2233: connecting to <AMP-ip>:443
    01:14:30  awc[2495]: tcp_connect: 168: recv timeout set to 5
    01:14:30  awc[2495]: tcp_connect: 175: send timeout set to 5
    01:14:30  awc[2495]: awc_init_connection: 2275: connected to <AMP-ip>:443
    01:14:30  awc[2495]: awc_init_connection: 2416: Connected
    01:14:30  awc[2495]: Sent header(len=311) 'POST /swarm HTTP/1.1^M Host: <AMP-ip>^M Content-Length: 0^M X-Type: login^M X-Guid: 37063276017716a872c7c438ce591959577a90f13d7fc40db9^M X-Name: CLUSTER-vc^M X-Organization: ^M X-Shared-Secret: ************^M X-OEM-Tag: Aruba^M X-Accept-Authentication: PSK,CERT^M X-Ap-Info: <serial>, <iap-mac>, AP-207^M ^M '
    01:14:30  awc[2495]: Message over SSL from <AMP-ip>, SSL_read() returned 157, errstr=Success, Message is "HTTP/1.1 401 Unauthorized^M Server: nginx^M Date: Wed, 12 Sep 2018 09:58:50 GMT^M Content-Length: 0^M Connection: keep-alive^M X-XSS-Protection: 1; mode=block^M ^M ", AWC response: (null)
    01:14:30  awc[2495]: disconnected from airwave <AMP-ip>
    # show log provision
    Provisioning Log
    Time                      State    Type         Log Message
    Fri Jan  2 01:08:22 1970  Airwave  Debug        Logging out of AMP server primary
    Fri Jan  2 01:09:23 1970  Airwave  In progress  Connecting to primary AMP server at <AMP-ip>...
    Fri Jan  2 01:09:23 1970  Airwave  In progress  Connected with primary AMP server <AMP-ip>, logging in...
    Fri Jan  2 01:10:25 1970  Airwave  Debug        Logging out of AMP server primary
    Fri Jan  2 01:10:25 1970  Airwave  Failed       Login aborted due to incomplete response from primary AMP server
    Fri Jan  2 01:11:26 1970  Airwave  In progress  Connecting to primary AMP server at <AMP-ip>...
    Fri Jan  2 01:11:26 1970  Airwave  In progress  Connected with primary AMP server <AMP-ip>, logging in...
    Fri Jan  2 01:12:28 1970  Airwave  Debug        Logging out of AMP server primary
    # show ap debug airwave
    Airwave Server List
    Domain/IP Address  Type     Mode  Config-only  Status
    <AMP-ip>     Primary  -     -            Not connected
  • 3.  RE: Clear AMP swarm old entries?
    Posted Sep 12, 2018 07:07 AM
    Can you try edit the Virtual controller key of VC and check the status
    1) # show running | include virtual
    2) copy the virtual-controller key
    3) # conf t
    4) type in virtual-controller-key and paste the copied kay
    5) change th last 2 digit of the key
    6) # commit apply.
  • 4.  RE: Clear AMP swarm old entries?
    Posted Sep 12, 2018 03:43 PM
    Yes, comapring log output for other clusters, it appeard that virtual-controller-key is the same on all VCs. I had to modify virtual-controller-key on every cluster. For some reason, Airwave has configured same key value on every cluster's VC, while those IAPs have never worked in same cluster.
    Gladly I had only 3 to change, any way to deal with let's say 250 VCs?
  • 5.  RE: Clear AMP swarm old entries?
    Posted Feb 22, 2021 10:32 AM
    Thanks Pavan. Saved me today.
    Inderjeet Singh
