clear pass captive portal didn't redirect after login?
This thread has been viewed 46 times
  • 1.  clear pass captive portal didn't redirect after login?
    Posted Nov 21, 2014 02:33 PM
    I have configured captive portal on guest and when I login it stuck in this page with no redrection and when I type any web site it redirect again to login page what may cause ythis issue?
  • 2.  RE: clear pass captive portal didn't redirect after login?
    Posted Nov 21, 2014 11:05 PM
    What do you have set as your default destination in your self-registration configuration?
  • 3.  RE: clear pass captive portal didn't redirect after login?
    Posted Nov 21, 2014 11:40 PM
    default is google.com
  • 4.  RE: clear pass captive portal didn't redirect after login?
    Posted Nov 24, 2014 09:56 AM
    1. Go to your Guest Registration / Guest Self Registration in Clearpass Guest
    2. Click "Edit"
    3. Go to "NAS Vendor Settings" in the bottom right-hand corner > Default Destination
    Do you have "Google.com" in the "Override Destination" field?
    -Mike
  • 5.  RE: clear pass captive portal didn't redirect after login?
    Posted Nov 24, 2014 04:48 PM
    yes,
    I need to under stand how to configure server initated the RFC not the controller?
  • 6.  RE: clear pass captive portal didn't redirect after login?
    Posted Nov 24, 2014 06:45 PM
    In that same menu go to:
    NAS Login > Login Method
    You can select the controller or RFC method of sending a CoA. The RFC method is often used when doing a CoA to a Cisco switch. The controller based option does work great on the Aruba wireless platform.
    -Mike
  • 7.  RE: clear pass captive portal didn't redirect after login?
    Posted Nov 25, 2014 07:47 AM
    Yes thats True but if I make it server initiated what configs should i care about.
  • 8.  RE: clear pass captive portal didn't redirect after login?
    Posted Nov 25, 2014 09:30 AM
    Are you trying to do a captive portal redirect on a Cisco switch?
    Thanks!
    -Mike
  • 9.  RE: clear pass captive portal didn't redirect after login?
    Posted Nov 25, 2014 12:38 PM
    no I'm using Aruba controller
  • 10.  RE: clear pass captive portal didn't redirect after login?
    Posted Nov 25, 2014 12:41 PM
    Then you'll be fine with the controller CoA option.
    To make sure the CoA is enabled, go to the following:
    1. Clearpass Policy Manager
    2. Configuration > Network > Devices
    3. Choose your Aruba Controller
    4. Make sure that "Enable CoA" is checked
    Hope it helps!
    -Mike
