Clear Pass certification
  • 1.  Clear Pass certification
    Posted Nov 26, 2019 04:50 AM
    By using ClearPass, certificate is distributed to clients so that the client can access the network (EAP TLS). Clients can access the network by using distributed certificate. Once a client accessed the network, is there any way to deny that client  from accessing the network by making the distributed certificate invalid? Thanks in advance.
  • 2.  RE: Clear Pass certification
    Posted Nov 26, 2019 05:40 AM
    Hi Syazusyazu923,
    of cause there is a way. Key words are CRL or OCSP.
    Greetings
  • 3.  RE: Clear Pass certification
    Posted Nov 26, 2019 11:06 PM
    Thanks!
    I will check the information about OCSD in ClearPass!
    @airsecxd wrote:
    Hi Syazusyazu923,
    Greetings
  • 4.  RE: Clear Pass certification
    Posted Nov 28, 2019 11:03 PM
    Hi. I already configured authentication method to use the tls with ocsp enabled. In the ocsp settings, I inserted the ocsp URL, and successfully revoked the certificate. Unfortunately, I was unable to unrevoked the certificate so that the client can access the network again. Please give me some suggestion or hint. Thanks in advance!
  • 5.  RE: Clear Pass certification
    Posted Dec 03, 2019 06:16 PM
    As I understand certificate rules, revoke is one-way. To "unrevoke" you re-issue a new certificate.
  • 6.  RE: Clear Pass certification
    Posted Dec 03, 2019 06:27 PM
    As msabin stated, you can not "unrevoke".
    Your client needs to request and receive a new certificate from the PKI.
  • 7.  RE: Clear Pass certification
    Posted Dec 05, 2019 11:37 PM
    Again, thanks a lot! Finally got the answer for my question!
  • 8.  RE: Clear Pass certification
    Thank you very much!
