Clear Pass Redirect
  • 1.  Clear Pass Redirect
    Posted Sep 06, 2018 09:59 AM
    I am looking for additional troubleshooting steps to try and identifiy why clients on what appears to be random basis are not getting redirected to an internal website after a successful captive portal authentication. The client is approved in CPPM but is not acctualy provided access to the network.
    The scenario is:
    guest Aceess is sponsored
    The sponsor approves access
    the CPPM shows access is approved
    The client web page refreshes and the client clicks the button to move forward
    The client should then be redirected to an internal company web page (more than 90 percent of the time this works)
     - sometimes the client will not be redirected, and the client receives "the network you are trying to use may require a logon"
    This happens from time to time on random IOS, Android, Mac OS and Windows machines.
    I have checked the cretificates, they are in good order.
    Can someone provide possible next steps?
  • 2.  RE: Clear Pass Redirect
    Posted Sep 06, 2018 10:46 AM
    @AIRWIFI wrote:
    The scenario is:
    When this problem occurs, if the user tries to access another website are they redirected back to ClearPass to authenticate?
  • 3.  RE: Clear Pass Redirect
    Posted Sep 06, 2018 11:37 AM
    Charlie,
    when the user attempts to navigate away to another page they are redirected to the CPPM Portal page for Authentication.
  • 4.  RE: Clear Pass Redirect
    Posted Sep 06, 2018 12:09 PM
    Okay, that confirms the user is not moved from the pre-auth role to the authenticated role.
    What version of AOS is running on the controller? What version of ClearPass is running? Does ClearPass show an successful authentication to the controller via AccessTracker?
  • 5.  RE: Clear Pass Redirect
    Posted Sep 06, 2018 01:44 PM
    So i never see the client service indicating that the user has been Accpeted.
    The CPPM is version 6.6.3.89660
    and the Controller version is 6.5.1.9
  • 6.  RE: Clear Pass Redirect
    Posted Sep 06, 2018 01:56 PM
    Do you see the user being rejected?
  • 7.  RE: Clear Pass Redirect
    Posted Sep 06, 2018 02:23 PM
    No I acctualy dont see a reference to the service at all.
  • 8.  RE: Clear Pass Redirect
    Posted Sep 06, 2018 02:35 PM
    It sounds as though the controller is not triggered to authenticate the user.
    You can use the command "show aaa authentication-server radius statistics" to watch the controller's attempts to authenticate guests via Radius. Since there's no accept/reject in ClearPass, it would show up on the controller as a timeout if the ClearPass portal page is getting the client to trigger the authentication attempt successfully.
    Otherwise, you may need to turn on debugging to watch the client device's authentication attempts. It could be that they are hitting an idle timeout while waiting for the sponsor to approve access, or the device could be deciding to disconnect from the open SSID due to going to sleep, lack of Internet connectivity detected, or some other behavior. To enable the authentication debugging on the controller, enter the configuration terminal and apply the following config changes:
    "logging level debugging security process authmgr"
    "logging level debugging security subcat aaa"
    When you notice the issue occur, "show log system 50" should give more insight into what went on.
  • 9.  RE: Clear Pass Redirect
    Posted Sep 06, 2018 02:38 PM
    Thanks for the help Charlie.
    I will update this post when more information is gathered.
  • 10.  RE: Clear Pass Redirect
    Posted Sep 06, 2018 11:31 PM
    Post auth redirection cannot be guaranteed.
  • 11.  RE: Clear Pass Redirect
    Posted Sep 14, 2018 09:39 AM
    Cappalli,
    Some clients part of the time, are not correctly being authorized.
  • 12.  RE: Clear Pass Redirect
    Posted Oct 02, 2018 02:06 PM
    Currently my log states the following for the client who is not actually being authorized
    stm[4140]: <304003> <4140> <DBUG> |stm| read_station_statistics: ab:cd:ef:00:11:23 is not associated to 18:64:72:40:d2:b3; ignoring
  • 13.  RE: Clear Pass Redirect
    Posted Oct 02, 2018 07:36 PM
    That debug message indicates that the station is not associated, thus is can not be authenticated because it is no longer connected.
    i recommend you open a TAC case for further debugging beyond what can be accomplished on the forum.
